Removing power brake booster
Discussion in 'General Maverick/Comet' started by KauaiHi, Nov 4, 2011.
  1. KauaiHi
    KauaiHi Member
    1975 Mercury Comet 5.0 V8 2bbl (4door)
    Replacement ha 4 bolts but i only see 3 on original... it won't come out where there should be s fourth bolt... whyyyyyy?!?!?:cry:
  2. maverick75
    Mine has two on the left side and two on the right side.
  3. KauaiHi
    KauaiHi Member
    how do i get to it?
  4. KauaiHi
    KauaiHi Member
    i meant how do you get to the fourth bolt? it seems like its the only one attached behind the pedal assembly
  5. maverick75
    The two on the passenger side both look like they get removed from inside, then the other two look accessible from the engine bay.
