Removing those old gaskets
Discussion in 'Technical' started by Jaynik, Nov 6, 2005.
  1. Jaynik
    Jaynik Member
    So I gotta get all these old gaskets off my block now. Whats my best bet to get them off without damaging the surfaces, mainly the head gasket.:dance:
  2. stmanser
    Davenport, Iowa
    a single edge razor blade, a wire brush, wd40, scotch bright pad, 400 grit sandpaper, goo-gone, gasoline, terpentine, paint thinner
    any of these items will help you out and i have used all of them at times. just take your time, do not use screwdrivers if you can avoid them.. dont use a hammer, and be VERY CAREFUL with paint scrapers..
    take your time.. its not a race
  3. Ford_Motorheads
    Ford_Motorheads Ford Addict
    Phoenix, AZ
    1961 Falcon, 1967 Ranchero, 1969 Gran Torino GT, 1974 Ranchero GT 1976 Mustang Stallion, 1977 Mustang coupe, 1978 Mach 1, and 2 1978 Cobras
    Yep, what he said. :)
  4. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Permatex puts out a gasket remover in the form of a spray liquid that works great...I would still recommend the aid of a scrapper-blade.....either way,the new seal is as good as the parts are cleaned.......
  5. Mavaholic
    If you have a compressor, get a right angle grinder and some of those scotch bright rol-lock disc. It dosent get any easier than that.
  6. 71gold
    if it is going to the machine shop.. let them do it... they did a great job on mine.
    if not Dennis, has a great idea (y) ...frank...:bouncy:
  7. bmcdaniel
    I use an old wood chisel then wipe the metal down with acetone.
