Removing U joints to pull tranny
Discussion in 'Technical' started by Halebopp, Apr 21, 2005.
  1. Halebopp
    Halebopp Member
    Ankeny Iowa
    Hey guys, can someone tell me how to proceed with removing the u jounts on my 74 Comet, it has clips holding the U joints together. Do I just drop the rear u joint or do I need to drop the front, or both?:huh: It looks like I need a needle nose to squeeze the clips, do the caps just fall out when those clips are removed, I need to know what to expect, I don't want to lose my needle bearings.
    I am installing a new flex plate and of course, dropping the drive shaft is one of the first things I have to do.
    I did U joints in a Pinto Wagon back in ,84 but they were held together with U bolts.
  2. Earl Branham
    Lugoff, SC
    Halebop; remove the little U clips on the rear joint, and slide the driveshaft out of the trans. There are two of them. That is all you need to do to remove the shaft. Leave the ujoints in place.
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Just remove the 4 1/2 nuts on the rear u-bolt holding the rear u-joint on. Drop the rear of the drive shaft and pull it out of the tranny. You don't need to remove any u-joints from the driveshaft ...
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    It is a good idea to wrap tape around the the u-joint to keep the caps from falling off while it is out of the car.
  5. stmanser
    Davenport, Iowa
    make sure you put something under the output where the driveshaft goes into in the tranny.....the fluid will get everywhere (assuming it is an automatic tranny)
  6. 71gold
    "I did U joints in a Pinto Wagon back in ,84 but they were held together with U bolts."
    these should be the same...frank...:bouncy:
  7. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    I hate Pintos...:D
  8. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    back in October, I found I much quicker way to get the driveshaft out of your car :cry: ....but I am sure you would rather use the suggestions listed above:lolup:
  9. Halebopp
    Halebopp Member
    Ankeny Iowa
    Thanks for this info guys, but I'm a little confused, I saw no U bolts, just clips , I looked at the back ones, and there are 4 clips 2 on the drive shaft, yolk, and 2 on the yolk going into the rear end, Maybe I am not looking close enough, does the mounting of the U joints vary? Thanks for the tips
  10. dmhines
    Cumming, GA
    Remove the two u-bolts ... you can see one in this picture ...
  11. Halebopp
    Halebopp Member
    Ankeny Iowa
    Oh by the way.. I hated pintos too, until I owned my 1990 wagon, it went through Ice and Snow like it was nothing, I was very surpised, incidentally, common misconception,
    the majority of the pinto car line's existence , they did not, have issues with exploding gas tanks
    once they went to 5 mile per hour bumpers.. problem solved.
  12. Halebopp
    Halebopp Member
    Ankeny Iowa
    Thansk for the Pict and I see you marked that one, fo rkeeping it in phase, I'll have a relook, maybe I was at a bad angle, I was on one knee looking under it on stands
    Again the collective knowledge of MAvericks on this site, is fantastic, Hey someone should collaberate, an dput to gether a maverick Comet, manual including picts and procedures people have performed and documented.
    You guys are greatly appreciated, want everyone to know that, I can't tell you how much money I have alrady saved, formt he good advise on this site.:clap: (y)
  13. Halebopp
    Halebopp Member
    Ankeny Iowa
    too bad I cannot gain real typing skills, I can spell with the best of them, just can't type worth a shevy
