Bad year for my Mav - death by a thousand paper cuts. Fuel gauge sending unit and speedometer cable crapped broke so I was driving without gauges, oil leak at the valve cover, brake master cyl etc. etc. and then my driver's side window roller snaps off. Now I am left with a nub and I can't figure out how to get the dang thing off. No clips or screws or any indication I can see to pull it off. I'm sure I am overlooking the obvious. (it is a 71 if it makes a diff). Can anyone help?
There is a sticker/decal covering the phillips screw. Use a screwdriver to poke a hole in it or pry it off. New ones are available from AutoKrafters.
Thanks Craig. It looked to me like solid metal all around. I figured there had to be a cap or a decal or something. Tnx for the AutoKrafters tip too.
YA, unfortunetly, FORD is much better at hiding things now. I should know, I have never been more pissed off at fixing something than the head gasket on my 94 tbird.
