Replacing leaf springs
Discussion in 'Technical' started by Hairy W Bush, Nov 7, 2015.
  1. Hairy W Bush
    Hairy W Bush Member
    Georgia
    1972 Maverick Grabber
    I have 24 inch tall rear tires and I'm wondering if the 3 leaf that's on there right now will be enough. The driver side springs is shot and rubs bad so I think it would be hard to tell now rather than if it weren't. I like the height where it is now so I'm asking.
    Also I want to upgrade from the rubber bushings. Are these right?
    http://www.summitracing.com/parts/ptp-6-1054/overview/year/1972/make/ford/model/mustang
    http://www.summitracing.com/parts/ens-4-2135r/overview/year/1972/make/ford/model/mustang
    not sure what the difference is either.
  2. 71gold
    will these bushings be used for street or strip?
  3. Hairy W Bush
    Hairy W Bush Member
    Georgia
    it's a street car
  4. dyent
    dyent Member
    vancouver bc
    1st one will not work, Mustang Shackle bushings are too big at 1 3/8" diameter, out Mav/Comets are 1" diameter, which is same as 68-73 Mercury Cougars.
    2nd set, only the front eye bushings will work, pretty well standard for most Fords RB82 I think is the correct part number........
    David
  5. Hairy W Bush
    Hairy W Bush Member
    Georgia
    crap. where can I get a poly set for the rear?
  6. dyent
    dyent Member
    vancouver bc
    see if Summit has them for 67-70 Cougar, 1" diameter........Energy Suspension, Prothane, get the black ones as they are graphite impregnated, self-lubricating bushings..........
    David
  7. Hairy W Bush
    Hairy W Bush Member
    Georgia
    i looked it up for cougar and nothing. weird. i don't even know what size to look for because i believe poly and rubber are sized a little differently
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    What is rubbing? 24 inch tires are pretty short.
  9. Hairy W Bush
    Hairy W Bush Member
    Georgia
    quarter panel. if that's normal size then I'll stick with the 3 leaf.
  10. tody
    tody Member
    cologne, germany
    mustangsunlimited carries the poly bushings for the rear.
    so a search on here, i posted the part number a while back.
  11. Hairy W Bush
    Hairy W Bush Member
    Georgia
  12. dyent
    dyent Member
    vancouver bc
    those are the correct size for the rear shackles only, the front eyes are much larger and ones from 65-70 Mustang will work...........
    David
  13. Hairy W Bush
    Hairy W Bush Member
    Georgia
    I'm confused now because above, you said it was 1"
  14. dyent
    dyent Member
    vancouver bc
    Here's a picture of both leaf spring bushings, the larger one (2") goes into the front eye of the leaf spring (one towards the front of the car) it is called the front hanger bushing and the smaller 1" is the rear shackle bushing, one for the rear of the leaf springs. You can PM (start a conversation) with me if you are interested in these Poly bushings.
    David
  15. Hairy W Bush
    Hairy W Bush Member
    Georgia
    Well I ordered the leaf springs today and I got the bushings all in the same order. I was told 2 1/16 on the front and the shackle bushing is correct at 1".
