Repro Gas tank?
Discussion in 'General Maverick/Comet' started by Draco, May 30, 2007.
  1. Draco
    Draco New Member
    Parkersburg, WV
    1971 200 inline-6
    My gas tank is shot all to heck. Could someone please point me in a good direction so I can find a repro tank?
    thanks!
    Austin
    (Formerly Maverick-AR)
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
  3. 71gold
    you can also get a (new) tank for '76-'77 at advance auto parts. you will have to get the straps also..(y)
    ...:bouncy:...
  4. Draco
    Draco New Member
    Parkersburg, WV
    1971 200 inline-6
    Are there any differences between the '71 and the '76-'77 tanks?
  5. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    I don't know about if there is a difference in how it installs but the answer is yes, Late model gas tanks were 19 gallons and early Maverick tanks were 15 Gallons
  6. 71gold
    straps are longer...that is the only diff. i see in install...i used my '73 sending unit...(y)
    ...:Handshake ...
  7. Draco
    Draco New Member
    Parkersburg, WV
    1971 200 inline-6
    Thanks fellas, Looks like the repro '76 from advance is the right way to go for me, as I don't have the place or ability to do the fab work for a mustang tank.
    once again thanks!
  8. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I wonder why he didn't just use that tank as a drop-in unit, like it was designed. As opposed to re-engineering a mounting system. :huh:
  9. Mavaholic
    The 76 tank uses a different type vent but the parts are available from Ford. The part numbers are in my article.
  10. yessubnevets
    yessubnevets New Member
    NJ
    1971 4 door Maverick
    JC Whitney tells me that they can special order the exact tank for the 71. I had to order one to replace my tank in my 71. I have not received it yet, but I will keep you updated. If someone knows different please let me know.
  11. Mavaholic
    I'd be real surprised if you actually get one.
  12. draggon13
    draggon13 Member
    Hilliard, Florida
    1974 Maverick V8 5 Speed
    I have a tank from a 74 Comet, 15 gallon looks to be in good shape, can pull tomorrow and give a better description and pics if desired, will include straps and vent, however the sender I need. It is available from AutoKrafters. If you are interested, let me know. I will take $100 plus shipping.
    rk
  13. draggon13
    draggon13 Member
    Hilliard, Florida
    The 71 is NOT a drop in tank, on the 70 models were IF I recall correctly.
    rk
  14. ratio411
    ratio411 Member
    Pensacola
    I know it wasn't originally a drop in tank.
    Wouldn't be hard to convert it that way though.
    That's all I was thinking.
  15. draggon13
    draggon13 Member
    Hilliard, Florida
    Sorry, didn't catch that. I never thought about it that way.
    rk
