Reproduction parts update...........
Discussion in 'General Maverick/Comet' started by JOEXR793, Sep 19, 2007.
  1. JOEXR793
    JOEXR793 Member
    Cleveland Ohio
    I have a 1976 Maverick Stallion, and 85 More Mavericks and Comets in Inventory.
    The first parts have been checked and fit like a glove,,, all of the tweeking is done to the tooling on the first parts. They look and fit great.
    So around 9-26-07 the first Maverick/Comet parts will be off to powder paint,, These parts are as follows:
    (1) 1969 to 1973 under battery bracket.
    (2) 1974 to 1977 under battery bracket.
    (3) 1975 to 1977 RT outer frame rail cover. (Direct fit).
    we would like an Idea of how many will be needed on the first run. we are going to produce the parts in amounts of 30, if we get an order for more then this, we will run till the order is filled rounding off to the nearest 10.
    we will then tool up for a diferant part,,, revisiting a production part may take a while,, So please let us know so we can get every one who needs them taken care of,,
    Thank you.
    Joe
  2. Columbus Comet
    Columbus Comet Member
    Columbus, OH
    Thanks Joe, I'll take one 72 under batery bracket.
  3. RobertBailey
    RobertBailey MCCI & MCG Member
    Lenoir City, Tennessee
    1972 Grabber Clone,1970 Maverick, 1973 Grabber, 1973 2dr, 1973 Maverick(Parts Car) 2000 Ford SD Truck PowerStroke
    I'll take 3 battery brackets for the 69-73......depending on cost
  4. rayzorsharp
    Yes, do you have a cost on these parts yet?
  5. Jamie Miles
    If you don't mind me asking a dumb question, what is a "outer frame rail cover"?
  6. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    What is a frame rail cover? Jamie & me posted at the same time.
  7. scooper77515
    Ditto on the frame rail cover...:huh:
  8. JOEXR793
    JOEXR793 Member
    Cleveland Ohio
    The inner frame rail is a box,,,, the outer is just a cover,, if you look at your frame rail from standing near the tire of you car,,, that is the outer rail cover,, the inner Box rail will be out soon. the frame parts are an exact reproduction,, just a better grade of steel,
  9. don graham
    any idea of the prices of them all. and is the battery bracket just the bracket or the tray also?:)
  10. JOEXR793
    JOEXR793 Member
    Cleveland Ohio
    the bracket is not attached at this time,, it is just the bracket but 2 diferant types. I will have the prices once powder coating is done,, and it also depends on the order size,,
  11. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Hook me up for 69 battery bracket,,, still dont know what a frame cover is. Can someone (Craig) post a picture? Thanks dk
  12. rayzorsharp
    If you unbolt your front bumper, it's the part of the rail the threaded holes are in.
  13. Craig Selvey
    Please clarify.....the battery tray bracket....is it the "leg" for the battery tray?
  14. Mercurycruizers
    Venetia, PA
    ditto....
  15. Dave B
    Are the parts going to be Powder Coated? or just primed? Powder coating may be overkill, and be hard to refinish properly.
