RH Racing Mirror (parts available?)
Discussion in 'Technical' started by A_Bartle, Feb 19, 2008.
  1. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    I bought a set of used sport mirrors (often also called racing mirrors) to install on the yellow Maverick. Unfortunately they were sold as "great condition" but the right hand mirror "insides" were messed up, so much so that once I took them apart to paint, I found the inside filled with silicone chalk. This was no doubt to help hold the position of the mirror, which is the current problem. I was wondering, does anybody know if any of the re-pop dealers sell new "insides only", and if so, would they fit an original mirror? Or, does anybody have a damaged RH mirror that has good internal workings they would like to sell. I already spent a good deal of $ when I bought this set and I hate to have to buy another whole mirror only to fix the problem of the internal mechanism. Any help you can offer would be appreciated.
    Thanks!
    Art
  2. Craig Selvey
    What is wrong "internally"? It is the mirror.....or is it the bullet part where it mounts to the base?
  3. A_Bartle
    Michigan's Thumb
    Craig,
    It's the bullet part where it mounts to the base. I monkeyed with it to try and get it tighter, but the mirror still won't hold it's position since I've put it on the car.
  4. Craig Selvey
    I would take it apart and check out the hardware....maybe the screws are stripped out??
    Tae it apart and report back.
  5. A_Bartle
    Michigan's Thumb
    Craig,
    I removed the mirror last night and shot a photo. It seems like the the adjustment ball is too loose and I can't see a way to correct that. Can anything be done?
  6. Craig Selvey
    So it is not "the bullet part where it mounts to the base"...but the actual mirror itself. The only thing you can probably do is to replace the mirror part. Not sure if any Mustang places sell this part.
  7. A_Bartle
    Michigan's Thumb
    Has anybody had any success in repairing these things? Is there some way to tighten up the ball/socket?
  8. Earl Branham
    Lugoff, SC
    Al; I have a sport mirror that loosens up. There is a set screw on the side of the mechanism. You can reach it with a small screwdriver. Mine loosens up, even with locktite. See if that helps.
  9. A_Bartle
    Michigan's Thumb
    Earl,
    Thanks for the tip, however, mine is not loose due to the mounting screw, it's the ball being too loose in the socket that's the problem (see photo above). Loose is a strong word, it's not wobbling, but just loose enough that movement and vibration from driving the car (as well as opening and closing the door) makes the mirror move from where it was set. Just wondering if there is a fix for it, or if not, is there a replacement part available?
    Thanks....
    Art
  10. Chinguschild
    Chinguschild The Bass Player
    Orcutt, Ca
    71 Grabber
    I have never heard of anyone fixing these but I have one if you end up needing to buy one. Its red though.
  11. indyman13
    indyman13 Member
    Little Rock, Arkansas
    See if you can buy a compression spring (one that wants to "push out") at the hardware store that can be "wedged" between the bracket and the mirror housing. You might have to drill a small hole on the bracket and screw a sheet metal screw or machine screw through it and into the center of the spring to keep it from slipping out but it should provide (if you get the right tensioned spring) enough force to hold the ball against the socket.
