Rim rubbing after installing new barake pads on front of car
Discussion in 'Technical' started by pierce13211, Apr 17, 2011.
  1. pierce13211
    pierce13211 Member
    Corvallis,OR
    Hello !!! Hope someone can help
    I have a 1976 ford maverick with the 250 in line 6 engine and the problem I have is that about 3 years ago had installed after market rims when the front brake pads were already broken in - now that I have installed new ones I am having the caliper rub and scrape against the rim intermittently - would this be because of the the new brake pads pushing out the calipers on the front ??? and would spacers help this problem ??? I am in desperate need of an answer - I have never had to put spacers on before in all 14 years I have owned the car but I never put after market rims on till recently - so any opinions and or answers would help !!! THANKS -:(:(:(
  2. j miller
    Polson, Mt
    i had a similar problem on my car. it turned out that with new pads the body of the caliper would rub on one of the bump out in the molding. i few miinutes with a file fixed the problem. look to see where it is rubbing.
  3. Dave B
    What wheels are you running? If everything is stock, somethings wrong...
  4. CaptainComet
    What size rims are you running?
    14x7 is my guess. ;)
  5. Craig Selvey
    Sounds like your calipers have a little extra metal on them. Just grind the extra metal off. It will be a small amount...so don't go crazy.
  6. 71gold
    put the outside pads on a...belt sander...and sand off about 1/8" from pad...you got 3 years out of the last ones...:Handshake
    "about 3 years ago had installed after market rims when the front brake pads were already broken in."
