rim tire size help
Discussion in 'Technical' started by 302-72-mav, Aug 22, 2010.
  1. 302-72-mav
    302-72-mav Member
    sactown CA
    i have 275/50/17 's and want to run 245/45/17's
    on my centerlines
    link says that the 275's are 10.82 in wide and the 245's are 9.64 in wide
    and the rim width would be
    7.5 to 9.5 for the 275's
    and 7.5 to 9.0 for the 245's
    what's a good way to find out how wide my rims are without taking the tire off
    http://www.1010tires.com/TireSizeCalculator.asp?action=submit
  2. baddad457
    Go to yuor nearest tire dealer and let em use the calipers they use for the wheel balancing machine to see what width they are.
  3. 302-72-mav
    302-72-mav Member
    sactown CA
    i took some mesurments and it's 4'' on the front of the rim and 6 1/2'' on the back side
    and to the inside of the LIP of the rim is - outside 3 1/2'' and on the back side it's 6''
    and the tire was just under 10'' // that touches the pavement
    so about 9 1/2'' to 10''
    some pic's of rims if that may help :huh:
