rims and tires
Discussion in 'Technical' started by hottie2, Sep 25, 2006.
  1. hottie2
    hottie2 Member
    Gainesville, Florida
    1972 maverick
    so I am new to this posting thing and could not find an answer so far (sorry if it has been addressed already)
    I have a 1972 maverick and i just put in a rear end from a 73, now for the fun part- new rims and tires! i was wondering what sizes fit the best. it just got back from paint and my body guy forgot to roll the lip on the rear (grrr). any suggestions?
  2. maverick75
  3. ModMav71
    ModMav71 Member
    Sebring, FL
    I guess it all depends on what you like. 15's or maybe something larger say 17's? I like 17x8's and maybe 17x9's in the rear. 17's just look better on the car IMO.
  4. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
  5. PART-TIME
    PART-TIME Member
    Ocoee, Fl.
    Grabber Clone
    22's They'll roll the lip for ya.:D
    I like the 16's or 17's.
    Ken
  6. hottie2
    hottie2 Member
    1972 maverick
    ha, thanks! well i solved a big problem. dad bought a set of air shocks for my birthday (yay) so my rear is not as saggy so i am looking at 15's and 17's i think...
  7. stmanser
    Davenport, Iowa
    i just ordered some 15x8 rims with 3.75 back spacing
    i will be wrapping them in MT et streets when i get the money.
    i will let you all know how they fit when i get them finished.
  8. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Well Hottie!
    I don't think that you solved a problem by putting air shocks on, if anything you maybe looking at a future problem with the shock mounts ! I'v heard noithing but bad reports from guys who have done this to their Maverick,anyone care to chime in here and tell what they think?
  9. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i have 17x8 all the way around
  10. blugene
    :Welcome:
    Ok, i'll chime in...
    I hav'nt seen that shock mounts have gone bad but it seems it could as there is more load on them when using air shocks. I have them and I will eventually get rid of them as they cause a stiffer ride than I like. I like the way they feel when they are not full but I can't drive on any thing but a smooth surface or I risk taking off the sidewalls. My cornering is also suffering. Seems it does'nt lean properly or something at the rear. I think it is better to get better fitting wheels and/or do something with the diff/axles, but that could cost some $$. Good luck and let us know what you do.:cool:
  11. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    the correct way to do it is to re-arch the springs or buy new ones.....before I went with air shocks....I would buy the "add-a-leaf" universal kit that autozone/pepboys/o'rielly sells....for around $30 you can get the rear lifted back to stock height...... just my 2 pennies.
  12. blugene
    Does this stiffen the ride?
  13. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    yes, well it stiffens the springs...as bad as mine were, stiffer ride would be nice :D ...I put them on the yellow car...i will post some before and after pics.
  14. blugene
    So would you say it stiffens the ride but also allows for better handling? I think the air shocks create a sort of negative affect because the air is pushing instead of absorbing. Does that make sense?
  15. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    That makes sense too me :p
    I am not sure about the handling...I only had it out once after adding them. For those that know me know I drive like a little old man :evilsmile when I ain't in PINKY.
    I took the add-a-leaf off...I had them sitting around and just thought I would see what they did. I am ordering some new leaf springs.
    here is before and after.
