rims
Discussion in 'Cosmetic' started by 72mavsleeper, Mar 18, 2003.
  1. 72mavsleeper
    72mavsleeper Member
    tucson az
    1972 2 dr 302 mav
    did any maverick come w/ 500 rally racing rims? i picked up a pair for my mav for 20 bucks for the set of 4 at a yard sale but no center caps if anyone can tell me where i can get some caps similar to a mav or have a fors emblim on it would be great.thanx derrck
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    If you are referring to the Magnum 500 rims, yes. Here's a shot of a 77 with them. I believe they were available from 74 on. You can get the center caps from a number of places on the net, including ebay once in a while. There are a number of variations, but the ones that came stock on the Mav had a Ford crest on them, not the oval. I believe autokrafters carries them, or you can do a net search and find a number of places that sell them. Unfortunately, new they generally run around 30 bucks apiece.[​IMG]
  3. 72mavsleeper
    72mavsleeper Member
    tucson az
    1972 2 dr 302 mav
    thanks for the info. i really havent been able to find a whole lot so im asking everyone i know. by the was that is a nice mav in the pic. ill soon have my pics done so i can show you my 72 mav.thanx derrick
  4. Mavaholic
    Auto Krafters has the center caps.
  5. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Magnums...
    That pic of the Maverick shows the later wheels that came on Mavericks and Comets that is similar to the original Magnum wheels that were an option on Mustangs from '65-on.
    The difference is those in the pics have aluminum trim rings rather than being chromed. Some of the original Magnums were painted silver.
    I am not sure that they are called 'Magnums' in the later years.
    Seth
  6. Wes
    Wes Maverick Police Dept.
    Western Pennsylvania
    '76 Maverick Stallion '76 Maverick Metro Police K-9
    I believe that they were still called Magnums. If you look at the ads for replacement classic rims from places like Coker Tire, they still to this day call them Magnum. And you are right about the chrome rims being from the other models, not the Mavs.
  7. Craig Selvey
    On Mavericks/Comets they were called Styled Steel Wheels. Painted, not chrome plated.
  8. Jean Doll
    Palmerton, PA
    Craig is right about the rims being called styled steel wheels. My 77' Maverick has them stock from the factory .The window sticker I still have calls them styled steel rims. I got my center caps from Auto Krafters and I'm quite happy with them.
  9. Mavlover
    Mavlover Member
    N.C.
    77 Maverick and 88 Ranger GT
      File size:
      36.5 KB
      289
  10. Pegasus
    Pegasus Powder Coating Nut
    Channelview, Texas
    '76 Maverick 2 door 302 V8
    Doug (DAB) just brought me a set of those rims to powdercoat!
    They are pretty scarred up from the trim ring, have cobwebs and light surface rust and are generally pretty funky-looking right now, but nothing some chemical stripper, bead-blasting and polishing can't fix!
    Being a two-color job, I'll have to do a basecoat in chrome on the entire rim, then mask off all but the black portions with high-temp fiberglass tape then hit it with a high-gloss black. Once that is done and the masking removed, a third coating of clear over the entire rim should make it look better than factory ;)
    I've not done these types of rims yet, so I'm cutting Doug a break on the price ;)
    Only because I give a hoot (most P/C places don't), I'll also be coating the inside of the rim (that is covered by the tire) to guard against future rust or corrosion .
    Pegasus
  11. Wes
    Hey, Pegasus...when you get them done, post a pix of how they turned out. Having a Mav with the Magnums on it, I'd be curious how they look.
  12. DAB
    DAB MAVERICK/COMET ENTHUSIAST
    Austin, TX
    Here are the Styled Steel Wheels before powder coating:
  13. 72mavsleeper
    72mavsleeper Member
    tucson az
    1972 2 dr 302 mav
    heres my mav w/ magnums.i just repainted them black for a better look.
  14. 72mavsleeper
    72mavsleeper Member
    tucson az
    1972 2 dr 302 mav
  15. merc1mack
    merc1mack merc1mack
    North Carolina
    comet
    hub caps
    On my Merc1 I have 1969 GT wheels with center caps and trim rings. If anyone needs any hub caps for a Comet/Maverick or any Ford, let me know. I have a dozen. One is for a Fairlane, several are for Mavs, LTD's and Cougars.
