rims
Discussion in 'General Maverick/Comet' started by 73rustymav, Feb 11, 2009.
  1. 73rustymav
    73rustymav Member
    clear lake, califorina
    First car in my life 69.5 maverick built 250 inline swap. 73 maverick RIP
    i just picked up some slot mags, 2 15x10, 2 15x8. i need to know what back space/ tire size for my 73. will i need to roll the lips?
  2. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    I'm running 15x8 stock magnums in the rear and they can rub. 15x10's are gonna be tuff.
  3. 73rustymav
    73rustymav Member
    so i basicly wasted 70 bucks on 2 rims?
  4. CaptainComet
    It is possible that you won't be able to use the 10s, but not necessarily ... they might limit tire size though.
    You say you need to know the backspace ... that is built into the wheel. It is the distance from where the wheel bolts to the car to the inboard mounting surface where the tire mounts to the wheel (not the lip itself, but the inside edge of it).
    If you post that dimension, we can give you a better idea of what can be done here.
    Are you running the stock rear axle?
  5. Craig Selvey
    I don't see any way (well.....not without a lot of work) you will get 10" wide wheels on a Maverick. Did you waste your money? Nope....just put them on ebay.
  6. CaptainComet
    If they are deep-offset, they will fit. Outboard tire clearance might become the issue.
    I think Razorsharp is running 10" rear wheels.
  7. darren
    The 10's arent going to fit unless you lift the ass end really high so the tires stick out past the quarter. That looks silly though on any car. You can try the 8's on the back. I wouldnt try the 8's on the front. Even if the do clear they would be really hard on front end parts. Thats my 2 cents.
  8. 73rustymav
    73rustymav Member
    thanks guys just guess is 15x8 and 14x7on my car. i just couldnt pass up those slot mags
  9. Maverick Man
    California
  10. hotrodbob
    hotrodbob Member
