Ring and Pinion Question
Discussion in 'Technical' started by Resto, Sep 17, 2011.
  1. Resto
    Resto Benders Evil Twin
    Yuma AZ
    How can I find out what the gear ratio is in my rear end? There is no tag on it. The car is a 73 2door had a 250 I6 with a C4.
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    If you don't have the door sticker, raise just one rear wheel off the ground with the transmission in neutral. Have someone turn the raised wheel exactly one turn while you count the revolutions of the drive shaft. Divide the drive shaft turns by 2.
  3. don graham
  4. Resto
    Yuma AZ
    I guess Im doing Home Work tommorro. Thanks Don:)
  5. 71gold
    door stickers... don't mean squat on a 38 year old car...:rofl2:
    "raise just one rear wheel off the ground with the transmission in park. Have someone turn the raised wheel exactly one turn while you count the revolutions of the drive shaft. Divide the drive shaft turns by 2."
  6. rthomas771
    Quote from The repair manual:
    PROCEDURE FOR DETERMINING REAR AXLE RATIO
    1. Jack up the rear of the car enough to clear the rear wheels and place on jack stands.
    2. Place a horizontal chalk mark on the driveshaft and a vertical chalk mark on the inside of the tire.
    3. Slowly turn the driveshaft and count the revolutions it takes to turn the tire once. As an example if it takes 3-1/2 revolutions of the driveshaft to turn the wheel once, then the axle ratio is 3-1/2 to one or 3.50 : 1.
    If I was a betting man...I'd bet the driveshaft turns 2-3/4 turns or no more that 3 turns which is a 2.79 or 3.00 gear
  7. Resto
    Yuma AZ
    Its a 279 Thanks Don.
  8. tomboy
    tomboy Member
    will the drive shaft turn if the trans is in park?
  9. Jsarnold
    '72 Sprint
    No. :badwords: Thanks for the correction. Post is edited to say "Neutral".
  10. Resto
    Yuma AZ
    The sticker is original and the car is in original condition, only 2 owners.
