Ripped a ball joint boot. Can I get replacement at local parts house?
Discussion in 'Technical' started by scooper77515, Mar 4, 2014.
  1. scooper77515
    Swapping in the drop spindles and noticed a tear in one of my boots. I have had the spindles on at least 4 separate times, and apparently snagged one with my joint puller.
    Can I get a replacement Mustang II boot at Oreillys/Autozone/Napa or is it a special order part?
  2. Mavman72
    You should be able to get a boot all by its lonsome I have in the past but, they tend to be generic and dont fit as well as original.
  3. blugene
    I have had problems finding them in the past.
  4. scooper77515
    Do you remember where you ended up finding one?
  5. Dave B
    Peel it off, clean it up, and take it with you, and see what you can find. Or maybe call Rod &Custom, they may be able to tell you what they use, and a part number?
  6. blugene
    I agree with Dave..
    At that time I worked at Pep Boys and they had a "Help" section. They had a "Help" book in the parts dept so I had one of the counter guys order me one. Took awhile..
  7. scooper77515
    I have it off and in a ziplock. I may give rod and custom a call and see what they use, and what will fit.
  8. John Holden
    John Holden Member
    NJ
    Just Suspension used to have them in different colors.
  9. MICHAEL DAVIS
    MICHAEL DAVIS Member
    1973 Ford Maverick
    Lower ball joint dust boot cover $8.95
    www.autocrafters.com pg58 upper ball joints replaceable 19 to 30 dollars
  10. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Check Energy Suspension
  11. scooper77515
    Found some that I think will work at a local Mustang parts house. Will see in a few minutes.
  12. Dave B
    It's been over an hour...
  13. scooper77515
    Oh, sorry. Seems to be working fine. Still up on jack stands until I get the exhaust TIG welded. Hopefully tomorrow.
  14. 71gold
    got a pic. and part #?
    :whistle:
  15. scooper77515
    I bought two upper and two lowers, and tried them only on the one side with the ripped boot, just in case they somehow don't work. Kept the other side with the R&C boots. Yes, another experiment...:rolleyes:
    Upper-65-73 Mustang--C70Z-3105-B
    Lower-65-73 Mustang--C70Z-3105-A
    Look exactly the same, except lower one seems just a touch bigger at the base.
    New ones have the metal ring at the top. Rubber is a bit thicker on the newer ones, so they are a touch firmer, heavier. $6.95 each.
