Had some extra time today so i took out the rear seat(i'm going to be using a probe one)and the rear panels...found some rust...and some money too bad it was just penniesand then some strange little insects:16suspect PS:How to you remove the panel that goes over the seat belts?
You have to remove the entire seat belt assembly. There is no way to just remove the plastic. ....well...there is a way....it involves cutting or breaking something.
Eep. That sucks. But it does remind me.. this weekend while I was working on the Maverick I found a twenty crammed under the seat. It was my lucky weekend.
There will be bolts that go into the side of the seat belt assembly, their behind little round disc's that snap in, I can't remeber if there are 2 or 3?? remove the bolts and the whole thing will come out. Did you cut the seat belt?? as for the rust, thats nothing, scarpe up those pennys and get yourself some rust encapsulator. (you'll need a few more pennys)
yeah, i removed the 3 bolts but it still didnt come out. Some one cut them before my dad had the car.
They are also held on with an adhesive double sided tape. You will need to pry on it to get them out.
Here what mine looked like when I took them out.. Like he said put off the 3 caps, 3 big screws for the mounting, I got socket at advance to take the bolts right out..TOM
Thanks I got the probe seat in...just had to shave it and cut off the rods I'm hoping to re-upolster(cant spell) the seats on sunday
Please send me pics of it when your done. I have put probe buckets in the front of mine but didn't know the rears would fit good.
