Rivet removal
Discussion in 'Cosmetic' started by jasonwthompson, May 9, 2016.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Apparently my 72 Comet at one time had the factory body side molding that follows the body curve similar to a 73 Comet GT stripe, only higher up on the body. The paint on the car is very decent, but I need to remove the rivets for the body side molding. If anyone has done this, what is better, cutting them off and grinding them down, or drilling them out?
  2. Ronald Hopkins
    Ronald Hopkins Member Supporting Member
    Morristown Tennessee
    1972 Comet GT
    I don't think they are rivets. They were not on my comet. I just ground them off.
    jasonwthompson likes this.
  3. LittleJohnComet
    LittleJohnComet Member
    CA
    1972 Comet
    Late reply but I took mine off as well. I used a cutting wheel then carefully ground them down
    Spot primered for protection
    Probably going to pin strip along those tho to hide the work
  4. jasonwthompson
    Carrollton TX
    I was thinking about doing the same using the 73 Comet GT stripe and placing it up higher than normal.
    LittleJohnComet likes this.
  5. LittleJohnComet
    CA
    1972 Comet
    exactly
    That will look great
  6. Mavman72
    They are welded in place (Like a stud gun does) You can grind em off or...Really simple, and fast...Put a pair of vise grips on the head...Lock em down tight and just twist...They will just pop off this way...Quick and easy...
