rocker not getting oil
Discussion in 'Technical' started by Racer_X, Oct 9, 2012.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    today i primed the oilpump with the valve covers off to be sure all the rockers are getting oil and noticed that one of them isnt getting any oil at all. how do i fix this, and is it a sign of a bigger problem?
  2. simple man
    simple man Member
    Bunnell,Florida
    Assuming you are working on a V8, since the rocker oil comes up through the lifters and pushrods, try turning the engine while you are priming the oil. Sometimes it takes just getting the valve closed on that cylinder to let oil pass. :)
  3. Racer_X
    North Carolina
    yup 302 V8
  4. Racer_X
    North Carolina
    :bananaman it worked :Handshake
  5. 71gold
    by doing it that way, it will have to be turned over every time from now on to keep it oiling..:yup:.
  6. simple man
    simple man Member
    Bunnell,Florida
    Great! I hope you have the same fortune on the rest of the install! :thumbs2:
  7. Racer_X
    North Carolina
    gonna try and fire it up this weekend, fingers crossed
  8. junrai
    junrai Member
    rancho cordova ca
    good luck(y) as long as everything is in line like its supposed to be and youre getting gas and oil itll be a good day:yippee:
