Roller motor????
Discussion in 'Technical' started by rsillmon, Apr 5, 2009.
  1. rsillmon
    rsillmon Sneaky Snake
    Caroline,VA
    Maverick
    Hey, I will be using a 85' or 86' mercury that has a 5.0 fuel injection and how will I know if its a roller motor?: I always thought a roller cam meant having roller rockers and roller lifters? Thanks:)
  2. Bryant
    it will have roller lifters, not rockers. the only way i know of to verify its roller motor is to take off the intake and see if it has regular lifters or roller lifters with the spider and dog bones that keeps them orientated correctly in the block.
  3. yellow75
    Tillamook Oregon
    A roller motor has a roller cam and roller lifters but not roller rocker arms, it should be a roller motor byt the year you indicated. When youi take the intake off you will be able to see the dog bones that hold the roller lifters in the lifter bores.
  4. Jeff S
    Jeff S Member
    NoVA
    none
  5. rsillmon
    Caroline,VA
    Maverick
    Thanks!!
    Thanks for the infor. Also I assume that the roller cam is made out of a stronger steel than a regular cam, I keep hearing about you have to buy a steel distributer cam gear when installing a older type distributor?
  6. Jamie Miles
    It's questionable in those years if it's a roller or not. Some were and some weren't. Like was said, only way to know for sure is to pull the intake and see.
  7. baddad457
    You don't have to pull the intake, only one valve cover, one rocker arm and pull the pushrod out. A roller 302 pushrod is 6.25" long. But be careful when pulling the pushrod, if it's not a roller, the suction can and sometimes does allow the lifter to come up out of it's bore if it's a flat tappet lifter. They'll come up just enough to clear the bore, then the suction breaks and the lifter falls into the valley. Shaking the pushrod will break the suction.
  8. mean_maverick
    agreed. i pulled apart an '85 Crown Vic once and it wasn't a roller motor, but had a thottle body fuel injection setup on it.
  9. Dave B
    Or Variable Venturi???? Ewwwwwww!!
  10. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Not sure about this but couldn't you just pull the distributor and see what kind of gear it has on it to determine if it is a roller cam or not?
    I think they use a different gear than a regular flat tappet cam does right?
    Or am I wrong as usual? lol
    clint
  11. Mavman72
    Roller engines use a steel gear since the cam is made of steel.the non roller dist gears are sintered iron and to soft to put up with a steel cam.Visually the gears will look the same.
  12. yellow75
    Tillamook Oregon
    Yeah what he said. Thats a good tip on pushrod length though (y)
  13. bmcdaniel
    Actually, most roller cams are NOT steel, they are cast iron SADI cores with selectively heat treated lobes and distributor drive gears.
  14. Mavman72
    I love this place...learn something new every day!!! :thumbs2:
