Roller rockers
Discussion in 'General Maverick/Comet' started by Bob Wiken, May 6, 2008.
  1. Bob Wiken
    Fayetteville, Arkansas
  2. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    If you have stud mount heads.Not pedestal mount like stock GT-40 heads are.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    You might already know this, but you need your heads machined for screw in studs and guide plates. Once you do that, you need hardened pushrods too.
    So it's more than just buy and bolt on...
    They also require taller valve covers, or spacers to raise short ones up.
    That is a good price for rollers, assuming they are of reputable quality.
    *Those rollers- ~$140
    *Studs and plates- $50-100 depending on brand
    *Valve covers or spacers- $???
    *Pushrods- $50-150 depending
    *Machine work- $??? Was about $100 bux 10 years ago.
    Figure 2 bills today.:huh:
    *Head gaskets-
    *Etc, so on... you get the idea.
  4. Mavman72
    They wont fit your application unless you go to 7/16ths rocker studs(stock rocker studs are 3/8 Dia.).Your stock rockers are rail guided.(the tips of the rockers have rails on them to keep the rockers centered over the valve stem tips)You will need guide plates/push rods/screw in 7/16ths studs as ratio stated.So no, not on stock heads with no mods to allow them to work properly.
  5. bmcdaniel
    Hmmm, and for some reason they neglect to mention who the manufacturer is. Might be ProComp or some other Chinese knockoff artist whom it's better to stay away from.
  6. scooper77515
    The ones you want look like these...made by ford racing, and bolt right up to the GT40 and P heads.
  7. Bob Wiken
    thanks guys. You just saved me $150
  8. Bob Wiken
    oops
    :) that's it
