Rooster Comb..
Discussion in 'General Maverick/Comet' started by MaverickMan34, Jul 1, 2009.
  1. MaverickMan34
    MaverickMan34 Member
    Kansas City
    1970 Ford Maverick
    How can you tell if you're "rooster comb" slipped?
  2. Earl Branham
    Lugoff, SC
    Trans won't shift, or won't shift properly (with the shifter).
  3. MaverickMan34
    Kansas City
    1970 Ford Maverick
    it shift but doesnt go into gear. i took out the valve body but i have no idea how to tell if the rooster comb slipped off whatever its suppose to be on..
  4. darren
    OK I've been a tech for 20 years now and have no idea what the hell a rooster comb is. What gives guys? Detent?? :hmmm:
  5. Earl Branham
    Lugoff, SC
    Darren; it is the manual shift lever inside the trans. It has the detents in it and looks like a rooster comb. If the spring on the valve body is not lined up or in place, or the manual lever is loose or out of place, then the trans will have shift problems, or no shift at all. Anywho, that is what a "rooster comb" is.
  6. rthomas771
    This is a new one on me too. Kinda like hog heads and pumpkins I guess :huh:
  7. 71gold
    if you removed the valve body, you removed the spring plate with the roller on it that rolls on the...rooster comb..:yup:
  8. 71gold
    ...and...Boomarangs
    ...:rofl2:...
  9. MaverickMan34
    Kansas City
    1970 Ford Maverick
    so how do i tell?
  10. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    In my experience if you hold in the column shifter out of it's detentes or the floor shifter button in and you can move the shifter to all of it's positions without feeling any detentes or positions then the rooster comb is out of position.
    That make any since?
    clint
  11. MaverickMan34
    Kansas City
    1970 Ford Maverick
    I can feel the rooster comb clicking through the roler. but the transmission doesnt catch and it just stays in park??
    :huh:
  12. PaulS
    It is probably not engaged in the valve spool that controls the shifts.
    You will need to pull the pan to see if the manual valve is moving as the linkage is moved.
    If not then you will have to drop the valve body to get the valve and the stud on the "Rooster Comb" lined up properly.
  13. MaverickMan34
    Kansas City
    1970 Ford Maverick
    Thanks paul (y)
