rotors & wheels
Discussion in 'Technical' started by FoMoDave, Feb 27, 2006.
  1. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    For those of us that have done a disc swap using Granada rotors ,what wheels are you using. Aftermarket or OEM. It seems most wheel companies do not list the size of the center hole. I wanted to use 15x8 styled wheels but was told they will not fit.
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    I have 15x8 on mine....as long as they have 4 1/2 lug pattern, You can modify the center...I would!
  3. bmcdaniel
    I found out the hard way about the center opening after I put discs on the front. Got a flat tire on my way to Roundup last year and my old spare didn't fit over the disc's larger hub. Never had a problem with the 15x8 Cragers not fitting though.
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Aftermarket rims are going to fit without issue.
    It's the stock stuff that you have to worry about.
    I know 72 and earlier use small hubs, and that 74 up use large.
    Don't know about 73.
    I am swapping in small lug discs off a 68 Fairlane so I don't have that issue.
    Dave
  5. 71gold
    any 5 on 4 1/2 disc rim will fit. the "disc" is what gives you the big hole.
    ...frank...:bouncy:
  6. ratio411
    ratio411 Member
    Pensacola
    I don't mean to argue,
    much.... ;)
    It is the bearing size.
    My 72 drum rims won't fit my 75 drums or my 74 discs (large bearing spindles), however my 72 drum rims will fit my 68 Fairlane/69 Stang discs (small bearing spindles).
    Dave
  7. Mavaholic
    I have a set of 68 GT rims that I had to put on a lath and turn the centers bigger. It wasent much, something like 1/8" total.
  8. FoMoDave
    Cumming Ga.
    Thanks to all who responded. I will probly go with aftermarket wheels. I thought all Rangers had discs. I realy wanted to use repro styled wheels in 15x8 because I found them for $145ea. .Maybe I can find some Keystone Classics in the right size??
