Rough Idle 250 Six
Discussion in 'Technical' started by mleega1, Aug 12, 2007.
  1. mleega1
    mleega1 MAVERICK MARK
    Lagrange, GA
    1971 Maverick 2015 F150 2003 Explorer
    I have a 72 with a 250 and automatic. It has a rebuilt dist with a pertronix ing module. The problem is an intermittent rough idle.:cry: It will idle well for a while then gets very rough with the vacume guage reading "late ing timing". The timing is set at 10 deg and otherwise runs well. I do also have an intermittent lifter ticking. I have not been able to link the 2 together as they do not always coencide.:16suspect
    I would like to get your opinions before I replace the module. I also have a dsII dist and moduke from a "running" car that I could install. I understand that the hot wire goes to a switched ing source. any one know of a good place to locate this?
    Thanks as always:tiphat:
  2. 71gold
    Mark,
    it sounds like a carb. problem.
    did you check the filter?
    if this helps please let me know...i so want to be right once :yup:
  3. mleega1
    Lagrange, GA
    The filter is new, but I have a good known carb I can swap out and see if that is it. Thanks Ill let you know(y)
  4. newtoford
    newtoford Member
    New Castle Delaware
    make sure you chek for vac leaks, espically between the carb and intake.
    good luck
