rounded starter bolt?
Discussion in 'Technical' started by newtoford, Oct 25, 2007.
  1. newtoford
    newtoford Member
    New Castle Delaware
    whats the best way to break rounded nuts and bolts loose? its the lower starter bolt thats kicking my butt. its a 1/2in bolt but every wrench and socket i have slips and my channel lock isnt able to catch on either.
    any ideas?
  2. blugene
    Dremel? :huh:
  3. svthauln
    svthauln Member
    Mounds,Ok
    1972 maverick
    goto sears and get the rounded nut and bolt sockets.I saw them and thought there is no way the will work but it worked like a charm.They come in a set for different sizes.:thumbs2:
  4. newtoford
    newtoford Member
    New Castle Delaware
    that sounds perfect. hopefully they wont break my bank? i know craftsmen stuff gets a little pricy but im sure something lik that pays for its self.
  5. scooper77515
    Man, that SUCKS. Bad place to be working. I would suggest using LOTS of heat first, and then hitting it with the vise grips. A "lot of heat" means acetylene torch, not cigarette lighter (but stay clear of tranny lines, etc.). Then throw that nut/bolt/stud as far away into the woods as you can and replace it with a new set. It will just get worse the next time if you don't.
  6. newtoford
    newtoford Member
    New Castle Delaware
    ohh dont worry, that things outta here. i wouldnt put myself through that fight again for a bolt that i can get for a few bucks brand new.
    i'll try some heat but investing in that kit probably isnt a bad ida ither as much as im working on old cars.
  7. scooper77515
    That is such a tight place to work in...good luck with whatever you get to work in there.
    Luckily it is the lower one, not the upper one. That would be damned near impossible to remove it you rounded it out:mad:
  8. newtoford
    newtoford Member
    New Castle Delaware
    you know im working on a I6 right?
    i got all the room in the world around both bolts. the upper one i got under the hood and the lower one is right there when you lay under the car
  9. scooper77515
    OOPS!!!
    Thought you were working on a V8. Miserable place to be on a V8. Either bolt is difficult to get to...
    I don't know how easy you I-6 guys have it...
  10. blugene
    I feel like I had some of your :wine:cause one time he can't get vise grips on it and the next he has a world of space around it...:16suspect
    :p
    J/K New...I know it can be a pain when things are rounded.
  11. newtoford
    newtoford Member
    New Castle Delaware
    well i can get the vice on the head of the bolt no problm but whenever i turn it it slips off. then again maybe my vice sucks and isnt up to the challenge.
  12. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    the sears kit works really well. I got a couple bolts loose using it.
  13. newtoford
    newtoford Member
    New Castle Delaware
    ok i'll definatly be looking into that tomorrow.
    would home depo have something simular? i only ask b/c i drive by one everyday. guess i could take a look myself
  14. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    they might have something similar but it's not like the sears one and I can tell you that the sears stuff really works. Not really cheap, like 11-15 dollars. They have different size sets so make sure you know what size bolt you have.
  15. newtoford
    newtoford Member
    New Castle Delaware
    thats not too bad. thats for the set right? not a single socket?
    its a 1/2in if i remember correctly
