runs bad then good
Discussion in 'Technical' started by scott, Sep 11, 2005.
  1. scott
    scott Member
    new jersey
    1970...302 c4 hookers dynamax (for now)
    the situation:
    (250... 1972 all stock)
    runs great. normal gas mileage. but when i come to a stop, the engine shakes almost like it is running on 5 cyls. then the idle improves and smoothes out.
    so far i can tell you that:
    carb is a lil over a year old. plugs,cap rotor and wires are fresh. also thinking vacuumleak i went with new gaskets for the carb to manifold. tinkered with the mixture and timing. pcv is also fresh. even did a "gunk" engine flush thinking sticky lifter.
    i know it has to be something easy that i am overlooking... any other ideas? anybody else "been there done that?"
    thanks:hmmm::hmmm::hmmm:
  2. Craig Selvey
    Does the carb have a dashpot?
  3. scott
    scott Member
    new jersey
    no dashpot...never did have one..
  4. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    pionts
  5. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Vacuum leak!
  6. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    How are the floats on those carbs set up? Sounds like how a v-8 does if the floats are too high, causes extra fuel to overflow into the ventura and flood the engine. Once it burns the extra fuel out it clears up.
    clint
  7. Craig Selvey
    If you have a bracket for a dashpot..I think that would help. A dashpot keeps the butterflys from "slamming shut" when you let off the gas....which could be your problem. The dashpot "eases" the plates shut.
    P.S. By "shut" I don't mean 100% of the way...as the butterfly are open just a sckoshe when at idle.
  8. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    sckoshe? Craig-I had to look that one up.
    skosh [​IMG] ([font=verdana, sans-serif] P [/font]) Pronunciation Key (sk[​IMG]sh)
    n. Slang
    A small amount; a bit: “This is a well-plotted, economical thriller. Although the beginning is a skosh slow, [the author] picks up the pace” (T. Jefferson Parker).
    Here in NC we call that a smidgen.
    smid·gen also smid·geon or smid·gin [​IMG] ([font=verdana, sans-serif] P [/font]) Pronunciation Key (sm[​IMG]j[​IMG][​IMG]n)
    n.
    A very small quantity or portion; a bit or mite: “a smidgen of genius, a sliver of cutting truth” (John Simon).
  9. Craig Selvey
    I was using the Queen's English spelling. :D
  10. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    I was more baffled with the Queen's English meaning!
    Seth
  11. Tom Laskowski
    Bay Area,California
    Was the Queen in Japan?
  12. scott
    scott Member
    new jersey
    uhhhh i did forget to add i have a pertronix so i know it ain't the points....think i'll check the needle and float. i sprayed carb cleaner around the intake places checking for vacuum leaks with no real change in the idle. maybe i sould invest in a vacuum guage... as always, thanks for all the input.
