Runs Great!! 85% of the time....Help?
Discussion in 'Technical' started by SPSKY, Aug 2, 2012.
  1. SPSKY
    SPSKY Member
    Northern Jersey
    TBA
    I have been reading through post for the past 2 hours trying to find a fix to my problem and couldnt find anything, so I'm just gonna ask.
    I picked up a 1970 with a 250 automatic factory air car. The air was removed.
    It was sitting for a while so I has the carb professionally done, change plugs, cap, rotor, etc.....typical stuff you would do to a car sitting for 5 years. The only repair I had to made was on the heat tube for the choke. It was rotted out so I made a new one out of cooper line.
    Starts and runs awesome! I drive it around and every once in a while I'll get a hesitation and almost like a "bucking". I assumed vacuum leak so I checked all the hoses and replaced the bad ones and the problem is still there.
    I drove her for about 40 miles today and it comes and goes.
    Any suggestions you guys could give me would be greatly appreciated.
  2. bikerbuck65
    bikerbuck65 Member
    california
    maverick
    I would check the fuel filter,lines and or pump..Could also be just bad gas.
  3. SPSKY
    SPSKY Member
    Northern Jersey
    TBA
    Filter is new. I was thinking about the pump, but I wasn't sure if that would cause an intermittent problem.
    When I got the car the tank had pretty much no gas in it. I filled it up with premium gas and some additive.
    If nothing else comes up I'll give the pump a shot. Its like 20 bucks....worth it for piece of mind down the road.
  4. scooper77515
    If that tank was empty, there could be rust inside the tank, which would clog up a fuel filter quickly.
    Pop that filter off and take a look inside, you will know quickly if that is the issue or not.
  5. Bryant
    do you still have points in the distributor?
  6. Shinysideup
    Shinysideup Chillin the most
    town
    car
    Carb isnt done right.
  7. Joe Dirt
    Carb picking up some trash mine done simlar today with a skip at cruise and then wouldnt idle i done the old rag and rev trick and its back like glass
  8. SPSKY
    SPSKY Member
    Northern Jersey
    TBA
    I still have the points. Pertronix kit should be here by Monday. I'm gonna peek in the tank tomorrow and see what it looks like in there.
  9. SPSKY
    SPSKY Member
    Northern Jersey
    TBA
    What's the rag and Rev trick?
  10. 71gold
    it's an "Old School" way of clearing the carb by flooding it. :yup:
  11. Jory
    Jory Member
    Greenville, Texas
    1971 Ford Maverick 4-door
    I'm curious, please explain this so I can give it a shot on my car too. Thanks!:thumbs2:
