Rust in fender mount area, what to do?
Discussion in 'Cosmetic' started by YellowStangDuan, Dec 27, 2010.
  1. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    I have rust where the fender bolts on to the body, apron area? I guess this piece is not easily replaced. It is pushing the fender mounting area up, and I'm trying to fix all this before painting. What should I do?
  2. Craig Selvey
    Cut out the bad rust. Sand blast the rest. Weld in a patch panel. I have had to do this to all the Mavericks I have restored.
  3. rwbrooks50
    rwbrooks50 Member Supporting Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Duane,
    When are you coming to see me? I have all the patch panels you need. Or, I'll take your rust bucket as a trade-in on a good body. :rofl2:
    Rick
  4. YellowStangDuan
    Arlington, Texas
    71 Grabber
    Nope! After 30 years, me and this one can't part! How about tomorrow? Need directions and time...
  5. rwbrooks50
    Forney Texas
    I will be working near the house tomorrow. Come out I-20 East to Forney third exit, Helms Trail. I will meet you at the Shell gas station.
    Call when on your way.
    Rick
    214-673-8086
  6. darren
    My car had a few pinholes in that area on the pass side. We humm'd and haw'd over it then decided to cut a little square out and patch it.
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I can relate, mine had a couple pinholes too.:rofl2: Pinholes for hitch pins that is!
  8. sportyfamilycar
    sportyfamilycar ElMaverick
    KY
    (2) 77' Mavericks
    mine is identical, why do they rust there?
    im cutting out the pieces off my parts car and welding it in like others mentioned. fairly simple.
  9. darren
    The layers of steel overlap each other but arent sealed. The get all the road splash from the wheel. This was one of the first places to rot out up here in the salt belt. It would lift the edge of the fender up and bend the lip the rust was so thick. All the Mavs I had as a teenager in the 80's were totally rotted at all 4 of those joins.
  10. darren
    Ah thats nothin. Up here they would rot all the way down to that first bolt in the shock tower. (that was in the 1980's)Took a big patch to fix it.
  11. YellowStangDuan
    Arlington, Texas
    71 Grabber
    Ok, I'll just weld in some replacement. I was afraid it was done like that for strength purposes. If a section of sheet will do it, that's what I'll do! Thanks!!!
  12. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    So after its welded up, would some seam sealer on both sides be sufficient to keep it from rusting again?
  13. YellowStangDuan
    Arlington, Texas
    71 Grabber
    After a visit to Rick's house today, I see what it's supposed to look like! It's just thin stuff spot welded together, where mine rusted it was about 1/4" thick, I thought there was more to it. Simple fix, and I will used some sealer (silicone, since that's what's plentiful here) when I'm done.
  14. darren
    I soaked mine with rust check after repair. It doesnt see rain if possible so its not a concern anymore for my car.
  15. sportyfamilycar
    KY
    (2) 77' Mavericks
    have any of you ditched the inner fender *plastic* splash guard?
    mine was rough and i hadn't planned on putting it back on. didnt know if that will cause more harm :(
