Rust
Discussion in 'Cosmetic' started by Jim1970, May 29, 2006.
  1. Jim1970
    Jim1970 Member
    Wyoming
    1974 Mercury Comet
    Help!
    Found a small spot inside the trunk where rust has gone clear through, just behind the right rear fender well.
    I am not after a show winning car -- but I would like that rust to stop.
    Any simple solutions?
    Thanks in advance,
    Jim
  2. Mavaholic
    There's only 1 correct way to fix it. Cut out all the rusted metal and weld in new. Anything else would be a temporary cosmetic fix at best.
  3. Jim1970
    Jim1970 Member
    Wyoming
    1974 Mercury Comet
    So I need to contact a local body place and get their help, as this is not the kind of thing I can do.
    Is this a few hundred bucks to fix??
    Jim
  4. Jean Doll
    Palmerton, PA
    Just to cut and weld a peice in the trunk would probably run a few hundred bucks as long as the rust hole is not too big.
  5. |MaverickMat|
    |MaverickMat| '74 Grabber
    Portland, OR
    1974 Grabber
    Another option (temporary but inexpensive) would be to grind all the rust off, and patch it with fiberglass and rust preventative paint. POR-15 makes a good fiberglass kit (by temporary I think it might last you a few years). I will be going this route for a couple of my smaller holes.
