Sanding, grinding advice?
Discussion in 'General Maverick/Comet' started by Wolf Mcbee, Aug 5, 2015.
  1. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    I have recently purchased a grinder for the Mavericks body and floor, I bought grinder wheels, tested them on the metal, hehe well.... I sorta grined at an angle and made small teeth marks but I did it in a place where I was working on a huge dent anyways so I taped it off and marked the imperfection are, should I cut it and replace it with 18 ga metal or just get a welder and try to fill in the claw marks? Or anything to fill it in the I don't have to use filler, also I know to use sand pads on it not grinders, only for the floor so any advice on metal work thanks! I do learn fast so
  2. rthomas771
    Grinding wheels eat metal fast. A flap wheel will be more forgiving.
    cyclonewill and Wolf Mcbee like this.
  3. Eli Lacy
    Eli Lacy Banned
    1970 ford maverick(grabber clone)
    I have to say.... You have given me lots of good advice rthomas771!!! Thanks for helping us fellow members!!
    yellow75 likes this.
  4. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    Thanks!! Yea I was considering one but wasn't to sure, thanks again!
  5. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    flap wheels come in different grit sizes the lower the number the coarser the flap
  6. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    Yea I'm aware of that, I'm just going over all the paints grinding down the new(old) paint over the original paint and the primer so I have one layer and don't go to bare metal so I can do rest by using the flap sander when I get it all down to the one layer
  7. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    I've had good luck with a wire wheel on a grinder for removing layers of paint gently. You just have to take your time. I've gotten both front fenders on the kid's car down to original paint/ primer.
  8. tody
    tody Member
    cologne, germany
  9. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    a sharp razor blade will work great too you can peel the paint off down to the primer a friend of mine recently stripped a whole car with just a pack of blades ( he is retired with a lot of time on his hands)
  10. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    I tried that, I just kept cutting into the metal :whew::slap: after I used that grinder for one spot and got to bare metal, it was okay but I seen like dark marks and when I run my hand over it I can barely feel it but I wanted to feel smooth and feel nothing then "almost" perfect, so I had another idea, the first one made claw marks in the metal, the second one made real small scratches that were a little deep, so now (already did it and succeeded) I used the grinder to sand away the original paint, the recent paint, to the primer, did get a few spots to bare metal but went over it with some 180 grit paper and it's perfect, nice and shiny, and smooooooth to the touch so if anyone tries to sand there car then good luck and hope this helps, btw only paid 20 for the grinder and the grinder wheels were $8 for 4 (came with an extra for free cause of the grinder) I used an entire wheel just for one quarter panel and the floor pans and still has life in it for later use! :clap::bouncy:
  11. mav1970
    I agree with Jeff - I have used a ton of these wheels on my car - ones from Harbor Freight work just fine
  12. 7D2 Grabber
    7D2 Grabber Member
    Northern CA, Bay Area
  13. 7D2 Grabber
    7D2 Grabber Member
    This was the outcome
  14. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    A da sander with 80 grit works well too if you see sparks you are removing metal ,metal that usually has to be repaired
  15. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    So far I almost got all the floors sanded down and I bought some duplicolor rust spray, turns rust to primer to prevent rust in the future
