Schooling on interior door panels
Discussion in 'General Maverick/Comet' started by 19Grabber72, Aug 22, 2012.
  1. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    1972 Maverick 2 Door Sport Sedan Grabber
    Someone set me straight, lord knows I need it. I have noticed looking through salvaged cars of all the earlier models (69.5-72) that the interior panels on the doors are mostly all blk, or whatever interior color the car had and plain, and the door rests are the short/small ones.
    What is the interior style called that has the wood-like grain with the larger L shaped,if you will, arm rests? Those are also found in Torinos and Mustangs of the same years if anyone is looking.
    Again I know the later 73 n up models had the Mustang II style arm-rest that had the diagonal pull attached to the rest. I'm not talking about the those, only the 70-72s.
    Thanks, just trying to learn more about these beasts. :)
  2. Craig Selvey
    1972 Maverick Grabber - Color: Orange Also, 1976 Ford Maverick 4-door, 1977 Mercury Comet 2-door. Daily driver: 2002 Ford Focus SE Station Wagon
    Sounds like you are describing the deluxe interior door panels and arm rest.
  3. Dave B
    Wood grain is 73 & Up Deluxe door panels, but some 72 LDO's have the long arm rest, as found in the later years.
  4. Ronald Hopkins
    Ronald Hopkins Member Supporting Member
    Morristown Tennessee
    1972 Comet GT
    I think all 72 Comet GT's and all 72 Maverick Grabber's had the wood grain in the door panels
  5. Craig Selvey
    Not all 1972 Grabbers had the woodgrain. I have had two or three that did not.
  6. Mavman72
    My 72..."The never ending build project"...Has the wood grain panels with the long arm rests and chrome bases...Sort of a delux interrior but not an LDO car.
  7. Craig Selvey
    In 1972 that would have also been considered the deluxe interior.
    My pictures from above is a 1971 deluxe interior.
  8. Ronald Hopkins
    1972 Comet GT
    I thought all 72's had the wood grain and 71's had the woven vinyl inserts in the door panel. I never saw a 72 without the wood grain.
  9. rthomas771
    rthomas771 Member Supporting Member
    '74 Maverick 250 5-Speed.'60 Falcon V8 Toploader 9". '66 Falcon Sports Coupe, '63 Falcon Sports Coupe
    Here's my 72 parts car door panels.
  10. injectedmav
    injectedmav Member
    Georgia
    I have faux woodgrain in the door panel in my 72 Maverick with the long armrests? and armrest mounted inside door handle. I'm assuming it's considered the "deluxe" interior.
    My 72 Comet had the LDO interior with the door pull type armrests and the inside door handle mounted lower and forward in the door panel but no woodgrain, I assume the LDO's had the same sewn in pattern. It did have a woodgrain plaque on the RH side of the dash though.
  11. markso125
    markso125 Member
    Brigham City utah
    1972 maverick 2 door LDO
    The LDO's had the same door panel all the years available, there were just two color options for them too and they were LDO specific.
    Also the Wood inset on the dash was on all LDO cars. It was part of the luxury package.
  12. mrmalina99
    mrmalina99 Member
    Warner Robins, GA
    1973 Maverick
    This is what I have in my 73.
  13. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    What a conversation that started. Very Interesting . . . said with a heavy German accent l on Laugh In. lol
    I have the same door panel as posted by Mav Man in the above. However when I look at the other pic, the arm rest appears to be the short ones? or is that just the angle?
  14. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    So is there a set standard used then with a so called style option that a person would request. I heard a lot in the above--anyone have their purchase sheet from back in the day that would tell us what that was?
  15. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    So its a deluxe package then. I like the 71's better than the wood grain look! All the 71/72s Ive seen dont have the deluxe then at all. Interesting--what else would have then been a part of the deluxe package--just the panels or was that something attached with the bucket seats too?
