Scott Drake Roller Clutch Pedal Bushing Kit
Discussion in 'General Maverick/Comet' started by mvw66gt, Nov 14, 2019.
  1. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    Anyone use the Scott Drake roller bearing clutch pedal shaft bushing kit? Did you just use the bearing components and not the replacement shaft that comes with it? This is the kit for 65-70 Mustangs. Thanks, Matt
  2. bmcdaniel
    I have 'em. I kept the stock bar because I modified mine years ago to use a large lynch pin on the end instead of the goofy square retainer that broke and left me stranded. If you measure the diameter it should be the same as the stock bar. The only thing I used the bar in the kit for was to keep the bearings aligned while I welded them into the support bracket.
  3. mvw66gt
    mvw66gt Member
    71 Comet GT
    Thanks !
