Screeching Noise in 74 Maverick
Discussion in 'Technical' started by Regicide408, Jan 11, 2011.
  1. Regicide408
    Regicide408 Member
    Bay Area, California
    74 maverick i6
    Ok I have been hearing this noise with my mav for some time but now its getting worse. it makes this screeching noise mostly when its cold but now is seems that the car take really long to warm up. i did find something on youtube that sounds like the noise im hearing and i hoped that someone on hear has had that same issue and would let me know how to fix this issue. also the car takes long to warm up and it wants to turn off on me at stop lights i have to put it in nutral so it wont turn off. any ideas on these issues. any help would be great!!!:16suspect
  2. scooper77515
    Like the guys said, belt in most cases.
    I have also heard similar if water pump bearings, or idler pulley bearings are shot (on serpentine setup).
    But neither should affect how long it takes to warm up. might heat up faster...
  3. Bryant
    take off the belt and see if any of the pullys are hard to turn or are loose. if they are all good then then try a new belt.
  4. rthomas771
    A loose belt will glaze and loose traction on the pulley.The only real fix is to replace the belt.
  5. bmcdaniel
    I have a screeching noise in my Maverick, coming from the passenger seat. It's my girlfriend telling me to slow down...
  6. PaulS
    There is only one cure for that.........
    Get her her own Maverick!
