seat tracks
Discussion in 'Technical' started by mike75mav, Oct 20, 2019.
  1. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    I finally got my seats back from being reupholstered after 3 years. Now I'm putting the tracks back on the front bench seat and there not going on right. It seems the tracks need to a spacer from the seat frame to the tracks or I have the wrong tracks.
    This is a 75 Maverick 4 dr. Are all the bench tracks the same? If someone has tracks for a 75 can you send a picture of them.
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    Just a quite update. I think the problem is I'm missing spacers between the seat frame and the tracks. After, so many years I forgot on how to put it together. Anyone no on how much space there should be? I'll see if I can find them.
  3. Craig Selvey
    I don't think there are spacers between the seat and the seat tracks.
    Tannersg1 likes this.
  4. mike75mav
    mike75mav Member
    Bremerton, WA
    Here is the pic after I installed the tracks. I used a lot of washer to raise the tracks up for clearance for the lever to work.
  5. yellow75
    Tillamook Oregon
    That does not look like a Maverick seat
  6. mike75mav
    mike75mav Member
    Bremerton, WA
    It came out of a 1975 Maverick. I found it in a wreaking yard.
  7. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    I am with yellow75. Doesn’t look like a maverick seat. You should not need spacers with a stock seat between the rails and the seat frame.
  8. Tannersg1
    Tannersg1 Member
    Classified
    Those are not the correct springs for a Maverick seat. And you don't need spacers for the tracks.
  9. mike75mav
    mike75mav Member
    Bremerton, WA
    This is the part number for the seat. There is a metal tag on the springs. I do know it came out of a Maverick may not be a 75.
    D7bb6263100aa
    7 mgr 427 77
    501000 7 lb
  10. stumanchu
    stumanchu Stuart
    Portland, OR
    Someone with relatively short legs and long arms might stack washers in the front to put their shoulders a little further away from the steering wheel. If not Maverick, Fairmont? In 74, Mav seat belts came through the seat bottom to lineup with the bolt holes on the tunnel.
  11. mike75mav
    mike75mav Member
    Bremerton, WA
    This is what the seat looks like. I had it for over 10 years in the garage. There was 2 Maverick 4 dr side by side in a wreaking yard. One had a standard bench seat and than this one which a bench seat with an arm rest. I'm not really sure if it came out of a 75 it could be a 76 or 77. I not think any thing earlier. The reason I had to raise the seat up 2 inches was for clearance of the seat and floor boards so the seat can be adjusted forward and backward. The tracks did come from a Maverick.
    And no I don't have short legs and long arms. really
  12. mvw66gt
    mvw66gt Member
    Arthurdale, West Virginia
    71 Comet GT
    Your seat is out of a 78 Granada. They had that type of a seat. Probably why the tracks don’t work. Now someone could get you a set of Maverick tracks and you would be golden. - Matt
  13. stumanchu
    stumanchu Stuart
    Portland, OR
    I said that because I have short legs and long arms. I cant get comfortable until the seat it forward and the back is reclined a bit. the only way to do it in a non reclining bench seat is to jack up the front with spacers. I didnt mean anything else by it. But, I think you have a nice looking seat from the right side up view.
  14. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Seating position is a very personal thing. For me the key is to have adequate thigh support, or my right knee gets sore.
  15. mike75mav
    mike75mav Member
    Bremerton, WA
    The Maverick also, had that type of seat. That did not come out of a Granada or I would not get them.
