Secondaries finally opening, and other steps forward.
Discussion in 'General Maverick/Comet' started by Cometgt_71, Apr 11, 2016.
  1. Cometgt_71
    Cometgt_71 Member
    Saskatoon, Saskatchewan, Canada
    71 Comet, 2 72 Comet GT's , 73 Comet GT, 77 Maverick
    I have been trying to get my secondaries to open for quite a long time. I actually bought another carburetor, a Summit 600, seeing how my throttle bushings were wore out in my trusty autolite 4100, 480 cfm. Summit is good but it likes its gas, and I'm getting the car ready for a trip out west this summer. I thought I should reinstall the autolite for better mileage, so I rebushed it and rebuilt it. Ran awesome, real smooth but just didn't have the same power. Anyway, the issue was the throttle cable. It just wouldn't pull the plates open enough, not enough stroke. I ended up putting 3/8 shims behind the accelerator mounting plate (where it pivots under the dash) and this adds stroke to the cable. What a difference, I never had full throttle when I floored it before. Scared me a couple times. Let me know if there is a better way to adjust the cable please. The petal also doesn't bottom out on the carpet anymore.
    Also, I've been suffering with a wah wah wah noise forever and realized my transmission mount was torn in half. I have one ordered from summit. It's an anchor industries 2253, which cost $3.97. Does anyone know if this should fit a C4 in our cars? A friend lent me a used mount for the time being, it's used and rough, but the noise is about 75% gone. Sorry my posts are always long.
  2. junrai
    junrai Member
    rancho cordova ca
    sounds like youre getting it figured out. keep plugging away at it and eventually one day all youll be messing with are little cosmetic things like chrome door locks :thumbs2:
  3. 71gold
    see if you have any fluid leak at the tailshaft bushing/seal .
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    yep.. bad mounts eat rear seals and even the front u-joints if you drive them too long like that. The worst longer term cases can even eat the internal case bushing as well.
  5. Cometgt_71
    Cometgt_71 Member
    Yes it is leaking. I'll tap in a new bushing and seal. I remember scooper went through chasing a noise for years.
  6. groberts101
    groberts101 Member
    Minneapolis, MN
    Yes he did.. but remember that some of that turned out to be exhaust resonance and vibration due to improper shielding/separation of exhaust from the body.
  7. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Will a bad trans mount make that sound at low speeds, like 15 mph?
  8. groberts101
    groberts101 Member
    Minneapolis, MN
    I suppose anythings possible if something's a bit out of balance and exacerbating the issue but I would guess the front u-joint or pinion angle would be a more likely candidate to that type of issue. Problem is there's just soooo many things that can cause these types of issues, not to mention the individuals perspective and loss in translation when looking for help from others when sight and sound unseen. Heck, even internal bushing/bearing wear in the trans itself can add variable too.
  9. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    I have a vibration at highway speed while on throttle, I guess I better check the tranny mount. It seems harmonic.
  10. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    So when you let off the throttle and "coast", the noise goes away?
  11. NCFatBoy
    NCFatBoy Member
    Raleigh, NC
    1973 Ford Maverick
    Yes
