Semi-Automatic-Any Made
Discussion in 'Transmissions' started by roger628, Sep 8, 2006.
  1. roger628
    roger628 Member
    Seoul
    years ago 72 Comet LDO, 302, C4, PS , AC
    The original 69.5 brochure listed a semi-automatic trans. I have never seen one. Does anybody know if any were made or was cancelled at the last minute?
  2. Craig Selvey
    It was made. I have seen ONE in all my Maverick years.
  3. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    I've never seen one in a Ford but Mopar used to have a
    clutch-flight trans. Launched the car using the clutch and
    then autoshifted the other gears. VW also made a set up like that
    years ago. Neat idea.
  4. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    So whats the name of this tranny?
  5. mean_maverick
    i've read about this as well but dont know anything about them or have i ever seen one.... would be interesting though :yup:
  6. rayzorsharp
    That's always been my understanding...nothing special on the tranny itself.
  7. Andysutt
    Conway Arkansas
    1972 Comet GT
    So how is this semi automatic.... a c4 doesn't have a "clutch" like a manual transmission. So you can't "use the clutch to take off" and then it shifts auto...
    Or maybe im missing something?
  8. roger628
    roger628 Member
    Seoul
    Chevy offered a similar setup called Torque-Drive on 6-cyl Novas and Camaros, which was a Powerglide with no valve body. All shifting is manual. Start in low, move the lever to 2, then D as required. Come to a stop, do it over again. The first Hondamatics in the Civics worked this way too. They are a Torque Converter trans that has to be shifted manually. Where the cost savings over a full auto comes in, I don't know. Youd think that almost all of the components of a regular auto would be required
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Yeah, mopar made trannys like that, and Honda with motorcycles made um like that too. I have never seen, or never knew a mav had a trans like that. I learned something today.
    Dan
  10. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I am sure the manufacturer saved money by using a manual valve body...
    I have never seen one myself, but I think they were more of a Pinto tranny than Maverick, even though they were available in Mavs.
    Dave
  11. Rando76
    Rando76 Member
    Claremore, OK
    ...and on the cars that had the semi-auto, was the shifter on the column? I've heard of these but have never seen one. How would it be easy to identify without driving it?
  12. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    It was on the column and looked just like a standard C-4 ... However , the shift indicator was clearly stamped - Semi-Automatic ... I think somebody was selling the Semi-Auto indicator recently either on here or eBay ...
  13. Craig Selvey
    Dan is correct.
  14. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I saw one in a 69.5 in a bone yard here like 10 years ago......
    Never thought anything about it until I saw this thread.
  15. awannabegrabber
    awannabegrabber Always Learning
    Wichita, Kansas
    1976 Maverick with a trim package
    so it has 3 pedals, and there is no converter. so its a stick for the launch and then you drive it like a normal auto? i wish had a trani like that
    I would have nobody ask to drive my car :rofl2:
