Semi-automatic transmission
Discussion in 'General Maverick/Comet' started by WA8DDN, Jan 9, 2014.
  1. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    '74 Grabber, 302,C4,3:80 to 1 Traction lock. 1973 V8 car,LDO
    I took delivery of my 1970 Maverick on 6/18/69. Vin-0X91T139277. I bought a hard back Chilton's "Repair and Tune-up Guide". In this book they list three transmission options: Code 1-3 speed manual, Code V-semi-automatic stick shift and Code W-automatic (C4).
    The description of the semi-automatic is as follows: It is a manually operated power shift transmission which does not require a clutch pedal. It is similar to the C4 except for changes in the control valve body and that the vacuum diaphragm, throttle rod, governor and the inner and outer downshift lever assemblies have been eliminated.
    My question for the experts on this forum is: Did they produce any Mavericks with this transmission?
  2. Acornridgeman
    Wisconsin
    Yes they did!
    It was sure weird driving them. You basically dropped it into low at a stop sign and shifted up as you drove away. Just like a manual but without the clutch.
  3. Craig Selvey
    In all my years of messing round with Mavericks and parting out a bunch of them, I have only ever seen one.
  4. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    I never knew Ford did that at all..... Sounds basically like a C4 with a manual valve body.....
  5. Krazy Comet
    Yeah never enjoyed a huge fan base and I believe was discontinued after '70 or '71...
    Anyone know what the cost vs a "normal" C4???
    There are a couple picts of the quadrant n the gallery...
    semi_automatic.jpg [/img]
  6. WA8DDN
    WA8DDN Member
    Malvern, Ohio
    According to Wikipedia it was a $121.00 option and discontinued after the 1970 model year.
  7. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    Chevy used to have the same option in 1970 it was for the extreme cheapskate to save gas
  8. Acornridgeman
    Wisconsin
    I drove one once and remember it only had 2 speeds Hi and Low. :)
  9. OLD GOOSE
    OLD GOOSE Member
    WV
    1972 ford maverick
    YEAH A POOR MAN'S POWERGLIDE LOL:biglaugh:
  10. krelboyne
    krelboyne Remember
    Salem, Oregon
    I would be interested to know how many cars came with this option. If anyone ever thinks to ask Kevin Marti, please post the numbers.
