Serpentine belt swap
Discussion in 'Technical' started by FoMoCo73, Apr 28, 2010.
  1. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    '73 302 parts car 1969 1/2 351w/tko-500 in progress
  2. Bryant
    it should work. its ment for a reverse rotation water pump. that accessorys on a 351 are usally further away from the water pump so there shouldnt be any clearance issues.
  3. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    i just want to run alternator and water pump....and adjust tension with the alternator.... (manual steering)
  4. rthomas771
  5. FoMoCo73
    FoMoCo73 Member
    S.E. Wisconsin
    rthomas... they dont say anything about a 351 tho....
  6. 302-72-mav
    302-72-mav Member
    sactown CA
    so if he runs it like a normal v belt then he wont need a reverse waterpump
    would this work
    i went to manual steering to on my 302 //so all i would have to do is buy this setup and the alt watter & crank pullys would line up ??
  7. monstermav
    monstermav Member
    utah
    77 maverick 4dr 351
    I don't know if it would work because of the taller deck height on the 351. The bolt holes might not line up.
  8. 302-72-mav
    302-72-mav Member
    sactown CA
    ha ha ha ha the pullys are the same ones
    just a $60 difference WOW same part# and everything :dancing::dance::clap::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2::rofl2:
  9. Mavman72
    The water pump pulley is smooth in that kit. So WP is driven by backside of belt.Wont work on a std roataion conventional (to mavs/comets)ALT/WP/Crank set up.
