serpintine belt and pully swap
Discussion in 'Technical' started by bowstick, Apr 8, 2008.
  1. bowstick
    bowstick Member
    baton rouge
    1972 maverick 302
    well...i was wondering if anybody has done this....also will the pullies and brackets (from a 87 to 93 mustang GT) bolt up to the 302?
    on another note...where can i find a repair harness...and a new motorcraft voltage regulator?
  2. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Yeah I just recently did this swap, It was pretty straight forward. You have to take all the brackets from the donor car, then you'll have everything you need. You will also need the water pump from the mustang. I deleted the power steering in my setup and need a 72.5" belt to make it all work.
  3. Mavaholic
    I used a March kit from Summit.
      File size:
      195.1 KB
  4. 71gold
    Dennis,
    did you have to use the mustang waterpump?
    i put '84 C.V. setup on my '72 302...bolt on.
    had to take it off...wouldn't work on my new 5.0 w/A/C.
    Frank
  5. baddad457
    On an 87-93, you also have to swap the timing covers. The coolant ports are reversed as well as the pump rotation. At some point in between 79 and 87, Ford revised the timing covers on the reverse rotation setups with regards to the coolant port layout. The pumps will bolt up, but the gaskets and flanges don't align.
  6. Mavaholic
    I used a aftermarket water pump specifically for the Maverick.
  7. Rando76
    Rando76 Member
    Claremore, OK
    Hope this helps.
  8. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Here's a shot before mine went in.
  9. Ryan
    Ryan Ford Addict
    Phoenix Az.
  10. 72MAVGRABHER
    Roanoke, Va.
    Thats how I did mine.... The alternator takes up the slack so you dont need a tensioner... do need a standard rotation waterpump (grooves instead of smooth) though... got one from a 90 crown vic with a 5.0 Mine looks just the same. Alternatively, i'm only running an alt and water pump from the bottom end.
