Setting points?
Discussion in 'Technical' started by BrianB, Dec 17, 2010.
  1. BrianB
    BrianB Member
    1973 Maverick
    Someone told me a matchbook can be used to set the points? has anyone tried this?
  2. rthomas771
    Matchbook will get you home but to do it right you need a dwell meter
  3. baddad457
    Ditto, you must use a dwell meter to get it set right. And then checked every few months to keep it right. That was the problem with points, the rubbing block on the point set wears and changes the dwell setting. Replace it with an electronic module and all problems associated with points goes away.
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Words of wisdom! If you drive the car much at all this little mod will pay for itself in short order.
  5. bmcdaniel
    In an emergency once I set the points using a folded dollar bill.
  6. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    You might want to search down pertronix ignitor II amazing set up and no more points
  7. PaulS
    If you want to keep the points (some of us do) then get a dwell meter and find out what works best for your car - as long as it is within specs. I find that 28 degrees works best on the V8s for me in my vehicles. Yours may be different. The gap is .017 - .018 on my distributors.
  8. 302-72-mav
    302-72-mav Member
    sactown CA
  9. mojo
    That may work for those who have roller camshafts! For those who don't - I don't think so.
  10. 302-72-mav
    302-72-mav Member
    sactown CA
    i don't have a roller cam
    i just swaped the gear from my stock dist to the new one:rolleyes:
  11. baddad457
    :huh: Did you have to cut a hole in the hood to clear the distributor cap ? :D
  12. 302-72-mav
    302-72-mav Member
    sactown CA
    nothing like a distributor hood scoop
    if going with this distributor you will need new wire's may i recommend the moroso wires they are suppose to be better than the MSD wires:D and they look sweet and have shrink wrap on all of the boots ( and only like 60 bucks ) at summit get the ones for the 90's 5.0 mustang
