Sheetmetal valve covers, no pcv fitting. How would I run these?
Discussion in 'General Maverick/Comet' started by scooper77515, Jan 21, 2010.
  1. scooper77515
    There is no hole for the pcv, and no baffle. Can I make these work without to much...work?
  2. mean_maverick
    drill hole, install rubber gromment, install pcv valve
    that's what i did with a set of aluminum valve covers a few yrs ago :huh:
  3. rthomas771
    or cut the hole with a hole saw and use one of these.
  4. Bryant
    its a good idea to have a baffel under the breather or use some sort of baffeled breather. those billet ones posted look like a good way to go.
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Billet Specialties makes a cap with PCV in it.
  6. scooper77515
    Hmmm...good suggestions.
    I just didn't know off the top of my head.
  7. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    those look awesome are you planning on putting one hole in it for the pcv or just a breather? If you want just a breather you could use one of these from moon eyes
    but you still have to worry about putting oil in the motor:cool:
  8. maverick75
  9. 71gold
    the same style i have...
  10. scooper77515
    I will just pour it into the dipstick tube...:biglaugh:
  11. markso125
    markso125 Member
    Lewiston Ut
    Sorry guys I am ressurecting this thread so I can find it when I am not at work, I am trying to decide if I have enough to buy some of these right now.:thumbs2:
  12. 302-72-mav
    302-72-mav Member
    sactown CA
    yes it sure is
    and as for puting oil in the motor if you put pvc holes just pull the pvc out and poor the oil in with a funnel ?
  13. Earl Branham
    Lugoff, SC
    I had the same problems, and even with a small baffle, it used oil. I made a baffle for the pcv the same size and depth as the stock valve cover, and it is fine, except under high rpm. Don't know if the pcv is the culprit on those occasions, but so far, it is all I can think of. Here are a few pics of the baffle.
  14. scooper77515
    Earl, will those clear 1.7 roller rockers? That is the only fear I have. I had to beat the baffle down on one of mine to make them clear.
  15. Earl Branham
    Lugoff, SC
    Scoop; these valve covers are tall, and I have plenty of room. I use the 1.6 rockers that are stock, but I have loads of room over the baffle. BTW, how have you been?
