SHift Lever Bushing
Discussion in 'Transmissions' started by Jsarnold, Sep 13, 2011.
  1. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Does anyone know where I can get a new bushing for the shift lever at the bottom of the steering column, in front of the firewall, for a '72 Maverick column shift C4? Please ignore the rod in that bushing in the picture. Its a lock down I'll use someday for a floor shift conversion. For now I need a new bushing for the column shift lever.
  2. cactusgrabber
    cactusgrabber Member
    Tempe, Arizona
    72 Grabber
    Hey Jim, I think this is Shift Linkage Bushing you are wanting...from Rock Auto or Mustangs Unlimited. ($ 1 to $ 5)
    * Update with a 2nd source from Mustangs Unlimited also below...in case one or the other is out of stock.
    (others can double check me on this...it says Mustang...but I think it is the same one for the Mavericks...I had a hard time finding this one awhile back also....and others may know more about how to properly press them in)
    I hope this helps.
    http://rockauto.com/dbphp/x,carcode...cubic_inch_L6_1BBL_Shift_Linkage_Bushing.html
    (The Rock Auto one is the same color as the Factory ones)
    (The Mustangs Unlimited one is Black color)
    http://www.mustangsunlimited.com/it...ubCategory=Shifter+Components&CatKey=EMUSTANG
    Here's a picture of one on a similar Column Linkage "Ear" (spun around the other way)
  3. Jsarnold
    '72 Sprint
    Roger,
    That looks like it. For $1 and $2 shipping I'll take a chance. (y)
    Thanks a lot for looking it up. :Handshake I wasn't finding anything like it.
    Jim
  4. cactusgrabber
    Tempe, Arizona
    72 Grabber
    And I updated the post with a 2nd Source from Mustangs Unlimited...see above....in case one or the other is out of stock for you.
    The Rock Auto one costs less, and is the same color as the Factory ones though.
  5. Jsarnold
    '72 Sprint
    Guess I didn't find it at Mustangs Unlimited 'cause I was looking for a bushing, not an "insulator". :huh: Nice to know they're available. Thanks again.
  6. Jsarnold
    '72 Sprint
    And, it DOES fit the '72 C4 column shift Maverick. :thumbs2:
  7. Dave B
    There are 3 different sizes available from Ford still, I posted the part numbers a few years ago. Be prepared for some work to get the rod, to go into the new bushing, they can be a pain.
  8. Jsarnold
    '72 Sprint
    Gotta put the "insulator" into the shift arm first. Then lube the end of the rod and squeeze it on with some channel locks. ATP part number FO-300 was right for mine.
  9. Craig Selvey
    Ford made s specail tool to install these with. Would sure love to find one!!
  10. cactusgrabber
    Tempe, Arizona
    72 Grabber
    I'll keep this in mind when I install mine! :)
  11. simple man
    simple man Member
    Bunnell,Florida
    If you have Advance Auto Parts, look in the " help " section. There is an assortment of them!:)
  12. Hippylong
    Hippylong Hippylong
    72 maverick, 64 dart gt v8 4spd,65 barracuda S v8 4spd
    I got this to see if it works on installing colum shift bushings in my 72 c4. 20210403_092704.jpg
  13. Craig Selvey
    Where did you get that? I have been looking for one for years.
  14. Hippylong
    Hippylong Hippylong
    Off of the net. But honestly it didn't work well. It says ford but its too generic.
    I say weld up some.. the be more accurate.
  15. rthomas771
    I made something that looks like that with a small bolt and large nut welded to the jaws on channel-loc. The next one I make will be made from a C-clamp
    Craig Selvey likes this.
