shifter linkage
Discussion in 'Technical' started by 71mavkidd, Jul 25, 2008.
  1. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    new driver seat and i got her running smooth BUT :( it will not shift:mad: the arm just moves wherever and does nothing under the hood :hmmm:
    HELP PLEASE i want to drive :cry:
  2. don graham
    Check the tranny fluid? Linkage hooked up to the tranny?:huh:
  3. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    all hooked up and i can shift by reaching under the hood just not from inside
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Auto or Manual? Check the bushings on the arms, they may be worn out.
  5. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    manual. the problem is that it will moving the arm inside doesnt move anything underneath the hood.
  6. Andysutt
    Andysutt '72 Comet GT
    Conway Arkansas
    1972 Comet GT
    How do you shift a manual transmission from underneath the hood??
  7. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    just move the arms that are coming off of it (y)
  8. Andysutt
    Conway Arkansas
    1972 Comet GT
    That would be an automatic....
    Never seen a factory stick shift maverick, but aren't they like mustangs etc? They have a shifter thats bolted to a top plate on the transmission?
  9. maverick1970
    Missouri
    Andy it is a three on the tree.
    Sounds like you might have the linkage bound between 2 gears.
  10. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    how can i check for that?
  11. Andysutt
    Conway Arkansas
    1972 Comet GT
    I also didn't know they offered those in mavericks. lol
    But like I said, never looked into that stuff, and haven't seen a manual in a maverick/comet. They've always been autos.
  12. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    i am not a big fan of the tree on the tree. i will ultimately put it in the floor but til then i want to fix it so i can drive it around town.:drive:
  13. maverick1970
    Missouri
    Do the levers move at the base of the column when you go through the motions with the shifter?
  14. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    no sir occasionally just a slight movement but they dont actually move anywhere if that makes sense :huh:
  15. maverick1970
    Missouri
    I have never torn apart a manual shift column. Maybe someone can post an exploded view of the column. I will try to see if I have something at home.
