Ok, my valve body is out and it seems that there are only two possible positions for the selector arm.......can someone assure me that this is right............
I am interested in the answer as well. I don't know when I'll make the switch. I got the shifter Friday. Do I also have to move the reverse light switch? I assume so.
you'll have to buy a neutral safty switch that mounts on the transmisssion. It all so runs the reverse light...so I've read in a post. I haven't gotten that far because I'm still on the problem of the selector. And many other promlems withe my engine swap too........the only good news is that I got my computer working and don't have to run to the local library to post questions.
gearshift that lever points to the front,leave it alone,get a B&M Z Gate shifter it comes with the needed brackets to make it work like a charm.i have a 73,works perfect....Jim
