Shifting hard
Discussion in 'General Maverick/Comet' started by Travis, Dec 14, 2007.
  1. Travis
    Travis Member
    74'Maverick
    Hi i have a 74 with a 250 column shift automatic when you really get on it it will wind itself out until you back of the accelerator then it will change and go on does anyone have a answer as to what this maybe and how i can fix the problem
    Any help would be greatly appreciated thanks
  2. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    don't be skeered and leave your foot on the gas it'll shift eventually... hahahahaha
    Seriously though my pickup truck does that when the temperature changes outside. I can't rememebr off the top of my head if it is when it is cold or when it gets hot but one way or the other it winds out and holds second gear until you let off the gas and press back down on it again then it shifts to 3 and O/D fine.
    I was told that I have a vaccuum leak somewhere and that is what causes it.
  3. Earl Branham
    Lugoff, SC
    Sounds like the vacuum modulator valve is kaputz. Change it out and enjoy the ride!
  4. 71gold
    vac. mod......or...kick down rod...needs adjusting...:yup:
    ...Frank...:Handshake
  5. DALMAV
    DALMAV Member
    DALLAS, TEXAS
    1977 250 I6 AUTO 2DOOR
    Mine did the same thing. Mod valve fixed it.
  6. Travis
    Travis Member
    74'Maverick
    How much is the part to fix it?
  7. 71gold
    check and see if it'is a 1 or 2 port mod....
    ...:yup:...
  8. 71gold
    ...under...$500...(y)
    ...:Handshake...
