shifting problems - 1976 mav
Discussion in 'Technical' started by FMSprint72, Jul 10, 2011.
  1. FMSprint72
    FMSprint72 Member
    Louisiana, Missouri
    1972 Ford Maverick Sprint
    Ok, (his son here), so my '76 is having some kinda issue, to start with what(not bad) it's an auto tranny, the shifting knob is loose, like I barely have to move it and I can get it in gear, but it won't stay in gear, it keeps popping out of gear, not slipping POPPING?? I don't know what is causing this, the tranny seems to be good. Please assist.
  2. Mavman72
    Shift linkage has worn bushings and or linkage needs to be adjusted properly...
  3. FMSprint72
    FMSprint72 Member
    Louisiana, Missouri
    Ok how to I go about fixing those?
  4. FMSprint72
    FMSprint72 Member
    Louisiana, Missouri
    how do i go about getting into it to check the bushings and linkage out?
  5. Mavman72
    You will need to get under the car and physically check the condition of the components. Note what is sloppy/loose.Then determine what is necessary to correct the problem with the shift linkage.
  6. Mavman72
  7. Mavman72
