Shock location 691/2
Discussion in 'General Maverick/Comet' started by Relivin1970, Nov 5, 2019.
  1. Relivin1970
    Relivin1970 Member
    Alberta, Canada
    1970 maverick,1972 Sprint
    1969 1/2 are the shocks both in front or both in the back on the rear end ?
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    All Mavericks/Comets I have seen are staggered with right front and left behind. If 69 did not have staggered, Ford typically mounted the rear shocks in front of the axle.
    Relivin1970 likes this.
  3. yellow75
    Tillamook Oregon
    The shocks will be in front of the rear axle on a 69 1/2
  4. Craig Selvey
    Factory was non staggered on any rear end that is not an 8", so that would include all the 69.5 and early 1970's that had the 7 1/4" rear axle (or whatever size it was)
    TeeEl and Relivin1970 like this.
  5. Krazy Comet
    Dismal Swamp
    According to FMPC there was only one left shock/spring plate for '70. The right were same both '70 & '71 with part number for left changing in '71. Soooo using the catalog, none of the '70s had staggered shocks. Going on past info errors, this may or may not be correct.
  6. Relivin1970
    Relivin1970 Member
    Alberta, Canada
  7. 73curtis
    73curtis Member
    ohio
  8. jasonwthompson
    Carrollton TX
