shock squeek?
Discussion in 'General Maverick/Comet' started by mavmanerick, Oct 6, 2007.
  1. mavmanerick
    royal city, washington
    when it gets cold out my front shocks or springs or something with the suspension starts squeeking hardcore.. i mean like when i push it up and down.. what is an easy fix for this?
  2. scooper77515
    Put some grease in the zerks behind the front tires. It is hard to get to, but I guarantee that will fix the squeek. Very common problem in our cars.
  3. mavmanerick
    thanks but what part are the zerks on?
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    It is likely the upper control arm bushings. There is a special kit (2 piece fitting) that can be installed without removing the control arm. These are available from the Mustang supply places. You may also want to check the Help section at the local auto parts store.
  5. scooper77515
    Take your front tire off, and it is straight in where the lower suspension doohicky meets the inner fender well. If you are sitting on the ground, it is about chest level and all the way in.
  6. mavmanerick
    ok i tried that and the squeeking didnt stop.. so i found some silicone spray and that did the trick (for now)..
  7. scooper77515
    What part did you spray to make the noise stop?
  8. mavmanerick
    mostly where the bottom of the spring sits and all over that area..
  9. scooper77515
    So the spring is squeaking on the perch?
  10. mavmanerick
    i guess...:huh:
  11. scooper77515
    That lower perch is sitting on a hinge...wonder if that hinge is what was squeaking:huh:
  12. mavmanerick
    during the summer when it was hot the squeeking went away but it came back when it cooled off..
  13. Jamie Miles
    Alto, GA
    I've had a few
    Both my '72 and '74 Grabber used to do that. A shot of PB blaster to the spring perch on the upper control arm would always stop it for a few weeks. The '74 stopped doing it permanently when I wrecked it ;), the '72 stopped when I rebuilt the suspension. My cars did it regardless of the outside temperature, but it was a little worse when it was cold out.
  14. 20cows
    20cows Member
    West Texas
    74 Maverick
    Mine squeaks like an old brass bed!
  15. captainmack
    captainmack Quad Door
    Mine squeaks so basd at times It's embarrasing to drive...people turn their heads.. The squeak is coming from up inside the shock tower at or near the top of the spring. I've sprayed all kinds of stuff up there to no avail..
    Just like the other guy said, you can bounce on the fender and hear it.. anybody ??? heeeeeelpppp... It ruins the fun..
