shock tower help/76 mav with 351w
Discussion in 'Technical' started by steve_m1987, Apr 5, 2011.
  1. steve_m1987
    steve_m1987 Member
    Syracuse NY
    1976 Maverick
    i'm putting the 351w in my 76 mav and i had a welder look at it and he wasn't sure if where the towers need to be moved in was part of the moter mounts or not, they look to be but the frame also connects to the mounts so i'm no to sure. i'm haveing someone who knows a lot more about car welding then this last guy look at it but i would like to know before hand, any help would be great, thanks Stephen M.
  2. baddad457
    You're way off base here. You can trim the tops of the towers only without getting into major work here. Start at the top, angle back slightly under the tower brace, then straight down cutting about an inch to an inch and a half deep to just above the upper control arm bolts (bout 1-1-1/2" above these bolts) allowing for the upwards movement of the control arm. You can try checking out mine in the photobucket link below, I believe I've got a couple pics there that show what I did. (Look on page 8) If this doesn't help, some one else should be able to get better pics to show what to do.
  3. 71gold
  4. Awesome_X
    Awesome_X Member
    Oklahoma
  5. steve_m1987
    steve_m1987 Member
    Syracuse NY
    1976 Maverick
    thanks
    thank you vary much, the first guy was going to give me a really good deal but didnt want to mess up anything but since its not going to hirt anything i think i'll cut the shock towers myself and then have him come in and weld, thanks again guys you all really got me out of this jam i found myself in lol.:bowdown::thumbs2:
  6. 71gold
    sorry...I was thinking he was installing a...350...:D
  7. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    It may payoff more down the road (408) :dancing:
  8. baddad457
    Actually he's off by 5. :biglaugh: 352 -347 = 5
