Shock Tower Interchange
Discussion in 'Parts Interchange' started by Salem, Aug 18, 2021.
  1. Salem
    Salem Member
    Missouri
    Hey everyone, one of my shock towers is shot and I don't feel comfortable with just repairing it, so I think I'm gonna replace them both. Tall order, I know...Does anyone know if the 67-68 (or ANY) Mustang shock towers are roughly the right dimensions?
    https://www.cjponyparts.com/shock-tower-driver-side-mustang-1967-1968/p/M219L/
    I figure it wouldn't be impossible to just place the new tower over the old one to check, but I'd really like to not spend the money if someone here has tried it.
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    They are Maverick specific.
  3. Salem
    Salem Member
    Missouri
    Dang, that’s rough. Oh well, time to call the scrap yard and see if they got any! :thumbs2:
  4. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    You might consider a Mustang 2 or AJE suspension setup if your removing the towers.
    Maverocket and jasonwthompson like this.
  5. Krazy Comet
    I can't say they are exactly same but, '66-'69 Fairlane & Torino are very similar. Possibly Granada are same, Mustang & '70-'71 Torino definitely different.
  6. TeeEl
    TeeEl Senior Member
    Colorado
    Granada might be the same. Personally, if my towers were so bad that they needed cut out, I would leave them cut out and install a M-II suspension as mentioned by others. That's a lot of work just to end up with the limitations of the original design...
    mojo likes this.
  7. Salem
    Salem Member
    Missouri
    Call me nostalgic lol. I'll definitely check up on a few different towers. Worse case scenario, I look around a few scrap yards, but that still puts me in the position of buying a used part that's known to fail. I'm not against a Mustang II swap, but in my mind the old limitations are part of the fun (and headache)!
    Part scarcity though...THAT'S the rough part...:16suspect:
  8. TeeEl
    TeeEl Senior Member
    Colorado
    What's wrong with your original towers? What does "shot" mean? They don't wear out, so if you're referring to rot, the rest of the car would likely be pretty rotted, in which case should be sent to the scrapper in favor of a car that is more solid...
    mojo and Ronald Hopkins like this.
  9. mojo
    IIRC, AJE or RRS makes a replacement panel unit, tower section, much smaller than OE towers. If I were eliminating stock units and want to stay w/ some semblance of towers; this may be something to consider.
    Salem and TeeEl like this.
  10. Salem
    Salem Member
    Missouri
    Definitely. If i cant find OE that’ll fit, i have some decent mini towers in mind to fall back on.
