Should be simple, but HELP!
Discussion in 'Technical' started by JohnnyMav, Apr 10, 2010.
  1. JohnnyMav
    JohnnyMav Member
    Leamington, Ontario
    1971 Blue Coupe.
    Okay, so this is gonna sound really un-technical, but I can't figure it out, please bear with me if I don't get the names of things right. I have a single barrel carb on a 170 i6, it hesitates when I accelerate, when I popped the hood, I noticed that there was a cable of sorts (a thin wire) that is connected to the butterfly in the carb....it was bent all up and shoved into a crevice in order to hold it open open at all times. I'm pretty sure this is my problem, so I "un-bent" it but can't figure out where it's actually supposed to connect to....any help out there for a rookie back-yard mechanic? :huh:
  2. rthomas771
  3. JohnnyMav
    JohnnyMav Member
    Leamington, Ontario
    1971 Blue Coupe.
    i figured it should be bent and attatched to something, instead, it was just crammed up and jammed to hold the choke open.
  4. JohnnyMav
    JohnnyMav Member
    Leamington, Ontario
    1971 Blue Coupe.
    thanks for the link, i can see the peice I'm talking about, the "fast idle cam link" and I can see that it is connected to , surprise, the fast idle cam, looks like i'm missing something to hold it together.
  5. Thrashin302
    Thrashin302 Member
    South Dakota
    My advice is to pull the carb off and get a Holley 2300 for her. you can get a re-man for about $75 to $100 probably even less on ebay.
  6. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    I gotta disagree just rebuild the one you got.....40.00 and a lil time JMO
